АГА...
Нашел такой вариант
Основной код
#include <Servo.h>
Servo doorServo;
Servo handServo;
int switch_pin = 2; //set switch on pin 2
//motor variables
int motorThrottle=11;
int motorDirection = 13;
int motorBrake=8;
int pos = 0;
int selectedMove = 0; //move selector
int Testmove = 0; //test mode: set to move number to test only one selected move
//(set to Zero to run normally i.e: roundrobbin on amm moves)
void setup()
Serial.begin(9600);
pinMode(switch_pin, INPUT);
doorServo.attach(9); //set door servo on Pin 9 pwm
handServo.attach(10); //set hand servo on Pin 10 pwm
doorServo.write(80); //set door to hiding position
handServo.write(0); //set hand to hiding position
//Setup Channel B, (since Channel A is reserved by door and hand servos and can't ber used at same time)
pinMode(motorDirection, OUTPUT); //Initiates Motor Channel B pin
pinMode(motorBrake, OUTPUT); //Initiates Brake Channel B pin
void loop()
if (Testmove != 0) {
selectedMove = Testmove;
//if the switch is on, then move door and hand to switch it off...
if(digitalRead(switch_pin) == HIGH)
if (selectedMove > 10) { selectedMove = 0; } //when all moves are played, repeat the moves from beginning
// below are all the "Moves" i designed so far, each is a function that is written below in the code, execuse the names, abit strange? yes as some are written in arabic
if (selectedMove == 0) { switchoff(); }
else if (selectedMove == 1) { switchoff(); }
else if (selectedMove == 2) { switchoffbitaraddod(); }
else if (selectedMove == 3) { crazydoor(); }
else if (selectedMove == 4) { crazyslow(); }
else if (selectedMove == 5) { m7anika7anika(); }
else if (selectedMove == 6) { m3alla2(); }
else if (selectedMove == 7) { switchoff(); }
else if (selectedMove == 8) { matrix(); }
else if (selectedMove == 9) { sneak(); }
else if (selectedMove == 10) { zee7(); }
if (Testmove == 0) {
selectedMove++; //swith to next move if not in test mode
// Library of moves
// basic move
void switchoff()
//Moving door
for(pos = 80; pos < 155; pos = 3)
doorServo.write(pos);
delay(15);
//Moving hand
for(pos = 0; pos < 129; pos = 4)
handServo.write(pos);
delay(15);
//hiding hand
for(pos = 129; pos>=0; pos-=4)
delay(15);
//hiding door
for(pos = 155; pos>=80; pos-=3)
delay(15);
// move 3: open and wait, then move hand and wait, then switch of and hide
void switchoffbitaraddod()
//Moving door
delay(15);
delay(800);
//Moving hand
for(pos = 0; pos < 100; pos = 4)
delay(15);
delay(1000);
for(pos = 100; pos < 129; pos = 4)
delay(15);
//hiding hand
for(pos = 129; pos>=0; pos-=5)
delay(15);
//hiding door
delay(15);
//move 4: open door then close it many times, wait, then quickly reoprn a nd switch off and hide.
void crazydoor()
//Moving door
for(pos = 80; pos < 125; pos = 3)
delay(15);
//hiding door
for(pos = 125; pos>=80; pos-=5)
delay(15);
//Moving door
for(pos = 80; pos < 110; pos = 3)
delay(15);
//hiding door
for(pos = 110; pos>=80; pos-=15)
delay(15);
delay(700);
//Moving door
delay(15);
delay(700);
//hiding door
delay(15);
//----of switch of----//
//Moving door
for(pos = 80; pos < 155; pos = 8)
delay(15);
//Moving hand
for(pos = 0; pos < 129; pos = 3)
delay(15);
//hiding hand
for(pos = 129; pos>=0; pos-=3)
delay(15);
//hiding door
for(pos = 155; pos>=80; pos-=15)
delay(15);
// move 5: open door, then move hand very slowly forward and back to hiding very slowly, then quickly close door
void crazyslow()
//Moving door
for(pos = 80; pos < 155; pos = 1)
delay(30);
//Moving hand
for(pos = 0; pos < 129; pos = 1)
delay(30);
//hiding hand
for(pos = 129; pos>=0; pos-=1)
delay(30);
//hiding door
for(pos = 155; pos>=125; pos-=1)
delay(30);
delay(100);
for(pos = 125; pos>=80; pos-=4)
delay(15);
//move 6:
void m7anika7anika() {
//Moving door
delay(15);
//Moving hand
for(pos = 0; pos < 70; pos = 1)
delay(15);
delay(800);
//hiding door
for(pos = 155; pos>=130; pos-=3)
delay(15);
//hiding door
for(pos = 130; pos < 155; pos =3)
delay(15);
//hiding door
delay(15);
//hiding door
delay(15);
handServo.write(40);
delay(1000);
//Moving hand
for(pos = 40; pos < 129; pos = 4)
delay(15);
//hiding hand
delay(15);
for(pos = 120; pos>=80; pos -= 1)
delay(15);
void m3alla2(){
//Moving door
delay(15);
//Moving hand
for(pos = 0; pos < 127; pos = 4)
delay(15);
//hiding door
delay(15);
delay(2000);
for(pos = 130; pos < 155; pos = 3)
delay(15);
for(pos = 155; pos>=140; pos-=3)
delay(15);
for(pos = 140; pos < 155; pos = 3)
delay(15);
delay(500);
//hiding hand
for(pos = 127; pos>=0; pos-=4)
delay(15);
//hiding door
delay(15);
void matrix()
//Moving door
delay(15);
//Moving hand
for(pos = 0; pos < 80; pos = 4)
delay(15);
for(pos = 80; pos < 129; pos = 1)
delay(30);
delay(300);
delay(10);
//hiding door
delay(15);
void sneak()
//Moving door
for(pos = 80; pos < 130; pos = 1)
delay(30);
delay(2000);
//Moving hand
for(pos = 0; pos < 40; pos = 1)
delay(30);
delay(500);
for(pos = 130; pos < 155; pos = 4)
delay(15);
delay(100);
for(pos = 40; pos < 90; pos = 4)
delay(15);
delay(500);
//hiding hand
for(pos = 90; pos>=70; pos-=4)
delay(15);
delay(100);
for(pos = 70; pos < 90; pos = 4)
delay(15);
delay(100);
delay(15);
delay(100);
for(pos = 70; pos < 129; pos = 4)
delay(15);
delay(15);
//hiding door
delay(15);
void zee7()
//Moving door
delay(15);
delay(2000);
//forward @ half speed to the left
digitalWrite(motorDirection, LOW); //Establishes RIGHT direction of Channel B
digitalWrite(motorBrake, LOW); //Disengage the Brake for Channel B
analogWrite(motorThrottle, 100); //Spins the motor on Channel B at full speed
delay(300);
digitalWrite(motorBrake, HIGH); //Eengage the Brake for Channel B
delay(2000);
//backward @ half speed to the right
digitalWrite(motorDirection, HIGH); //Establishes LEFT direction of Channel B
analogWrite(motorThrottle, 100); //Spins the motor on Channel B at half speed
delay(300);
delay(1000);
//Moving hand
delay(15);
//hiding hand
delay(15);
//hiding door
delay(15);
И модернизация
Использование "глаз"
#include
Servo doorServo;
Servo handServo;
unsigned long TimerA,TimerB; //timer for the movement detection routine
//motor variables
int motorBrake=8;
//Distance Variables
int motionPin = 3; //motion sensor pin on analog 0
int lastDist = 0; //to remember last distance
int currentDist = 0;
int thresh = 200; //Threshold for Movement (set it such that you get the desired sensetivity of motion detection)
int pos = 0;
//(set to Zero to run normally i.e: roundrobbin on all moves)
boolean randomize = true; // if true, the box will do movers randomly, if set to false then the moves will be done sequencially from 1 to 10
void setup()
Serial.begin(9600);
//Setup Channel B, since Channel A is reserved by door and hand servos and can't ber used at same time
void loop()
if (Testmove == 0)
if(randomize == false)
selectedMove = 0; //when all moves are played, repeat the moves from beginning
else
selectedMove = random(11);
else
Serial.println(selectedMove);
if (Testmove == 0 && randomize == false) {
selectedMove++; //switch to next move if not in test mode
// Library of moves
// basic move
void switchoff()
//Moving door
delay(15);
//Moving hand
delay(15);
//hiding hand
delay(15);
//hiding door
delay(15);
//Moving door
delay(15);
delay(800);
//Moving hand
delay(15);
delay(1000);
delay(15);
//hiding hand
delay(15);
//hiding door
delay(15);
void crazydoor()
//Moving door
delay(15);
//hiding door
delay(15);
//Moving door
delay(15);
//hiding door
delay(15);
delay(700);
//Moving door
delay(15);
delay(700);
//hiding door
delay(15);
//Moving door
delay(15);
//Moving hand
delay(15);
//hiding hand
delay(15);
//hiding door
delay(15);
void crazyslow()
//Moving door
delay(30);
//Moving hand
delay(30);
//hiding hand
delay(30);
//hiding door
delay(30);
delay(100);
delay(15);
//move 6:
//Moving door
delay(15);
//Moving hand
delay(15);
delay(800);
//hiding door
delay(15);
//hiding door
delay(15);
//hiding door
delay(15);
//hiding door
delay(15);
delay(1000);
//Moving hand
delay(15);
//hiding hand
delay(15);
delay(15);
void m3alla2(){
//Moving door
delay(15);
//Moving hand
delay(15);
//hiding door
delay(15);
delay(2000);
delay(15);
delay(15);
delay(15);
delay(500);
//hiding hand
delay(15);
//hiding door
delay(15);
void matrix()
//Moving door
delay(15);
//Moving hand
delay(15);
delay(30);
delay(300);
delay(10);
//hiding door
delay(15);
void sneak()
//Moving door
delay(30);
delay(2000);
//Moving hand
delay(30);
delay(500);
delay(15);
delay(100);
delay(15);
delay(500);
//hiding hand
delay(15);
delay(100);
delay(15);
delay(100);
delay(15);
delay(100);
delay(15);
delay(15);
//hiding door
delay(15);
//this move will open the door and wait for movement, if detected near the switch,
//the box will move first to the Right, and then to the Left, and finally the hand moves and turns off the switch
void zee7()
//open door
delay(15);
delay(1200); //wait to stabilize sensor readings after opening the door
// set the timer and read the sensor
// wait for movement that exceeds threshold or if timer expires (5 sec),
lastDist= analogRead(motionPin);
TimerA= millis();
while(millis()-TimerA <= 5000)
currentDist = analogRead(motionPin);
//Does the current distance deviate from the last distance by more than the threshold?
//if yes, then move box to the right
if ((currentDist > lastDist thresh || currentDist < lastDist - thresh) || currentDist > 300)
//forward @ half speed to the left (choose the speed and the delay
//(i.e delay(300) according to you box and battery voltage such that the movement throw is desirable)
digitalWrite(motorDirection, LOW); //Establishes RIGHT direction of Channel A
delay(300);
break;
lastDist = currentDist;
TimerB= millis();
while(millis()-TimerB <= 5000)
//did the box already move to the right and the current distance deviate from the last distance by more than the threshold?
//If yes, then move to the Left
//backward @ half speed to the right (choose the speed and the delay
delay(300);
break;
delay(100);
//Moving hand
for(pos = 0; pos < 130; pos = 4)
delay(15);
//hiding hand
for(pos = 130; pos>=0; pos-=4)
delay(15);
//hiding door
delay(15);
Нашел это
вот тут
Тургенев И.С.
