вот что у меня стоит в прошивке * Example: `M851 Z-5` with a CLEARANCE of 4 => 9mm from bed to nozzle.
* But: `M851 Z+1` with a CLEARANCE of 2 => 2mm from bed to nozzle.
#define Z_CLEARANCE_DEPLOY_PROBE 10 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES 5 // Z Clearance between probe points
#define Z_CLEARANCE_MULTI_PROBE 5 // Z Clearance between multiple probes
//#define Z_AFTER_PROBING 5 // Z position after probing is done
#define Z_PROBE_LOW_POINT -2 // Farthest distance below the trigger-point to go before stopping
// For M851 give a range for adjusting the Z probe offset
#define Z_PROBE_OFFSET_RANGE_MIN -20
#define Z_PROBE_OFFSET_RANGE_MAX 20
// Enable the M48 repeatability test to test probe accuracy
//#define Z_MIN_PROBE_REPEATABILITY_TEST
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
// :{ 0:'Low', 1:'High' }
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis stepper immediately when it's not being used.
// WARNING: When motors turn off there is a chance of losing position accuracy!
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
// Warn on display about possibly reduced accuracy
//#define DISABLE_REDUCED_ACCURACY_WARNING
// @section extruder
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true // Keep only the active extruder enabled.
// @section machine
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR false
#define INVERT_Y_DIR false
#define INVERT_Z_DIR false
// For direct drive extruder v9 set to true, for geared extruder set to false.
#define INVERT_E0_DIR false
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
#define INVERT_E4_DIR false
// @section homing
//#define NO_MOTION_BEFORE_HOMING // Inhibit movement until all axes have been homed
//#define UNKNOWN_Z_NO_RAISE // Don't raise Z (lower the bed) if Z is "unknown." For beds that fall when Z is powered off.
//#define Z_HOMING_HEIGHT 4 // (in mm) Minimal z height before homing (G28) for Z clearance above the bed, clamps, ...
// Be sure you have this distance over your Z_MAX_POS in case.
// Direction of endstops when homing; 1=MAX, -1=MIN
// :[-1,1]
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
// @section machine
// The size of the print bed
#define X_BED_SIZE 200
#define Y_BED_SIZE 200
// Travel limits (mm) after homing, corresponding to endstop positions.
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS X_BED_SIZE
#define Y_MAX_POS Y_BED_SIZE
#define Z_MAX_POS 200
* Software Endstops
* - Prevent moves outside the set machine bounds.
* - Individual axes can be disabled, if desired.
* - X and Y only apply to Cartesian robots.
* - Use 'M211' to set software endstops on/off or report current state
// Min software endstops constrain movement within minimum coordinate bounds
#define MIN_SOFTWARE_ENDSTOPS
#if ENABLED(MIN_SOFTWARE_ENDSTOPS)
#define MIN_SOFTWARE_ENDSTOP_X
#define MIN_SOFTWARE_ENDSTOP_Y
#define MIN_SOFTWARE_ENDSTOP_Z
#endif
// Max software endstops constrain movement within maximum coordinate bounds
#define MAX_SOFTWARE_ENDSTOPS
#if ENABLED(MAX_SOFTWARE_ENDSTOPS)
#define MAX_SOFTWARE_ENDSTOP_X
#define MAX_SOFTWARE_ENDSTOP_Y
#define MAX_SOFTWARE_ENDSTOP_Z
#endif
#if ENABLED(MIN_SOFTWARE_ENDSTOPS) || ENABLED(MAX_SOFTWARE_ENDSTOPS)
//#define SOFT_ENDSTOPS_MENU_ITEM // Enable/Disable software endstops from the LCD
#endif
* Filament Runout Sensors
* Mechanical or opto endstops are used to check for the presence of filament.
* RAMPS-based boards use SERVO3_PIN for the first runout sensor.
* For other boards you may need to define FIL_RUNOUT_PIN, FIL_RUNOUT2_PIN, etc.
* By default the firmware assumes HIGH=FILAMENT PRESENT.
//#define FILAMENT_RUNOUT_SENSOR
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
#define NUM_RUNOUT_SENSORS 1 // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each.
#define FIL_RUNOUT_INVERTING false // set to true to invert the logic of the sensor.
#define FIL_RUNOUT_PULLUP // Use internal pullup for filament runout pins.
#define FILAMENT_RUNOUT_SCRIPT "M600"
#endif
// @section machine
// @section homing
// :[-1,1]
// @section machine
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
* Software Endstops
#endif
#endif
#endif
#endif
- dark184
Нет концевиков, где они расположены физически и как настроены в прошивке.
Сначала в прошивке надо правильно настроить концевики с их физическим расположением на оси и к каким разъемам на плате они подключены. Далее выбираем куда хоумится, у вас в минус все оси
Далее проверяем куда двигается при хоуме, если все оси уходят в минус и там хоумятся, то все норма. Если ось или оси хоумятся не в ту сторону, значит меняем
для соответствующей оси с false на true. Настройка закончена.
Код: Выделить всё
// :[-1,1]
#define Z_HOME_DIR -1Код: Выделить всё
#define INVERT_Z_DIR falseКупил себе танк и никого больше не жалею.
dark184, // Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_Y_DIR true
// :[-1,1]
#define Y_HOME_DIR 1
вот что получаю #error "Enable USE_YMAX_PLUG when homing Y to MAX."
// :[-1,1]
- Mazayac
artem82, концевик стоит в min, стол движется в max - и это значит "всё хорошо"?
Вы уверены, что правильно понимаете, где начало координат этого принтера?
Последний раз редактировалось Mazayac 30 дек 2019, 14:20, всего редактировалось 1 раз.
Mazayac, а вообще есть какая нибудь литература описывающая все это
- Mazayac
artem82, общих алгоритмов нормально и универсально описанных я не встречал, каша обрывочная в интернете.
Местную Вики можно пошерстить.
Обычно всё ограничивается "подключите по схеме и залейте прошивку от производителя".
ну вроде заработало, всем большое спс за помощь и с наступающим новым годом! ну если че я еще вернусь)))
- dark184
Ну и правильно он пишет, у вас концевик на Y настроен на минимум, а нужно его тогда перестроить на максимум и подключить соответствующе. Т.е. у вас получается концевик Y все таки в максимуме стоит?
ну вот и новая проблема при печати тестового кубика на третьем слое останавливается печать???
Возможно неправильно откалиброван нагреватель хотенда. Вентиляторы обдува детали могут "сдувать" температуру и тогда принтер остановится если температура вышла за пределы. У меня так было...
а как разблокировать регулировку стола, где именно данная строчка???
- Mazayac
artem82, что пишет на экране при остановке?
теперь уже стол не хочет нагреваться до 90гр. при выставленной 110гр. хотя по напряжению 12.5 в ,
завтра заменю провода и проверю по новой
Стол снизу утеплен? Проверить, сколько реально вольт приходит на стол, померив напряжение прямо на клеммах стола. Предполагаю, заметно меньше 12в.
vl123
Коллеги, подскажите.
Поставил Platformio + VSCode, пытаюсь скомпилировать прошивку для платы SKR E3 DIP (писал про нее выше), для начала взял уже готовые файлы Marlin 2.0 отсюда:
https://3dtoday.ru/questions/proshivka- ... ent-620073
https://drive.google.com/drive/folders/ ... pfAapvjmUi
Получаю сообщение:
Warning! `env_default` configuration option in section [platformio] is deprecated and will be removed in the next release! Please use `default_envs` instead
Processing BIGTREE_SKR_MINI (platform: ststm32; framework: arduino; board: genericSTM32F103RC)
PlatformManager: Installing ststm32
Error: Detected unknown package 'ststm32'
The terminal process terminated with exit code: 1
Terminal will be reused by tasks, press any key to close it.
Как добавить этот самый ststm32 ?
Получаю сообщение:
