G-коды
Введение
N3 T0*57
N4 G92 E0*67
N5 G28*22
N6 G1 F1500.0*82
N7 G1 X2.0 Y2.0 F3000.0*85
N8 G1 X3.0 Y3.0*33
G92 E0
G28
G1 F1500
G1 X2.0 Y2.0 F3000
G1 X3.0 Y3.0
Обозначения:
{{yes}}
{{automatic}}
{{no}}
{{deprecated}}
Синтаксис (Fields)
В RepRap прошивках некоторые параметры могут состоять из нескольких отдельных цифровых значений, разделенных двоеточием. Как правило, это используется для задания параметров экструдера с одним значением, предоставленной в экструдер. Если только одно значение при условии, когда значение необходимо для каждого экструдера, то это значение применяется ко всем экструдеров.
In RepRapFirmware, some parameters can be followed by more than one number, with colon used to separate them. Typically this is used to specify extruder parameters, with one value provided per extruder. If only one value is provided where a value is needed for each extruder, then that value is applied to all extruders.
Letter Meaning
Gnnn Standard GCode command, such as move to a point
Mnnn RepRap-defined command, such as turn on a cooling fan
Tnnn Select tool nnn. In RepRap, a tool is typically associated with a nozzle, which may be fed by one or more extruders.
Snnn Command parameter, such as time in seconds; temperatures; voltage to send to a motor
Pnnn Command parameter, such as time in milliseconds; proportional (Kp) in PID Tuning
Xnnn A X coordinate, usually to move to. This can be an Integer or Fractional number.
Ynnn A Y coordinate, usually to move to. This can be an Integer or Fractional number.
Znnn A Z coordinate, usually to move to. This can be an Integer or Fractional number.
U,V,W Additional axis coordinates (RepRapFirmware)
Innn Parameter - X-offset in arc move; integral (Ki) in PID Tuning
Jnnn Parameter - Y-offset in arc move
Dnnn Parameter - used for diameter; derivative (Kd) in PID Tuning
Hnnn Parameter - used for heater number in PID Tuning
Fnnn Feedrate in mm per minute. (Speed of print head movement)
Rnnn Parameter - used for temperatures
Qnnn Parameter - not currently used
Ennn Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to consume.
Nnnn Line number. Used to request repeat transmission in the case of communications errors.
*nnn Checksum. Used to check for communications errors.
Комментарии
N3 T0*57 ; Это комментарий
N4 G92 E0*67
; Это тоже комментарий
N5 G28*22
Специальные символы
N: Номер линии
Пример: N123
*: Контрольная сумма
Пример: *71
Checking
Example: N123 [...G Code in here...] *71
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
The checksum "cs" for a GCode string "cmd" (including its line number) is computed by exor-ing the bytes in the string up to and not including the * character as follows:
int cs = 0;
   cs = cs ^ cmd[i];
cs &= 0xff;  // Defensive programming...
and the value is appended as a decimal integer to the command after the * character.
Buffering
If buffering is supported, the RepRap firmware stores some commands in a ring buffer internally for execution. This means that there is no (appreciable) delay while a command is acknowledged and the next transmitted. In turn, this means that sequences of line segments can be plotted without a dwell between one and the next. As soon as one of these buffered commands is received it is acknowledged and stored locally. If the local buffer is full, then the acknowledgment is delayed until space for storage in the buffer is available. This is how flow control is achieved.
Typically, the following moving commands are buffered: G0-G3 and G28-G32. The Teacup Firmware buffers also some setting commands: G20, G21, G90 and G91. All other G, M or T commands are not buffered.
RepRapFirmware also implements an internal queue to ensure that certain codes (like M106) are executed in the right order and not when the last move has been added to the look-ahead queue. This feature is not available in RepRapFirmware-dc42.
When an unbuffered command is received it is stored, but it is not acknowledged to the host until the buffer is exhausted and then the command has been executed. Thus the host will pause at one of these commands until it has been done. Short pauses between these commands and any that might follow them do not affect the performance of the machine.
G-commands
G0 & G1: Move
  • G0 : Rapid linear Move
  • G1 : Linear Move
Usage
Parameters
Not all parameters need to be used, but at least one has to be used
Xnnn The position to move to on the X axis
Ynnn The position to move to on the Y axis
Znnn The position to move to on the Z axis
Ennn The amount to extrude between the starting point and ending point
Fnnn The feedrate per minute of the move between the starting point and ending point (if supplied)
Snnn Flag to check if an endstop was hit (S1 to check, S0 to ignore, S2 see note, default is S0)1
Examples
G0 X12 (move to 12mm on the X axis)
G0 F1500 (Set the feedrate to 1500mm/minute)
G1 X90.6 Y13.8 E22.4 (Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material)
The RepRap firmware spec treats G0 and G1 as the same command, since it's just as efficient as not doing so.2
Most RepRap firmwares do subtle things with feedrates.
1. G1 F1500
2. G1 X50 Y25.3 E22.4
In the above example, we set the feedrate to 1500mm/minute on line 1, then move to 50mm on the X axis and 25.3mm on the Y axis while extruding 22.4mm of filament between the two points.
1. G1 F1500
2. G1 X50 Y25.3 E22.4 F3000
However, in the above example, we set a feedrate of 1500 mm/minute on line 1, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X and Y movement, so everything stays synchronized.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in such a way that ensures that everything moves smoothly together, and the right volume of material is extruded at all points.3
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G0 or G1 to send an E value that is less than the currently extruded length.
Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S parameter in this way, as damage may occur if you assume incorrectly. In RepRapFirmware, using the S1 or S2 parameter on a delta printer causes the XYZ parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1.
2In the RS274NGC Spec, G0 is Rapid Move, which was used to move between the current point in space and the new point as quickly and efficiently as possible, and G1 is Controlled Move, which was used to move between the current point in space and the new point as precise as possible.
3Some firmwares may not support setting the feedrate inline with a move.
4RepRapFirmware provides an additional 'R1' parameter to tell the machine to go back to the coordinates a print was previously paused at. If this parameter is used and the code contains axis letters, an offset will be added to the pause coordinates (e.g. G1 R1 Z5).
Some older machines, CNC or otherwise, used to move faster if they did not move in a straight line. This is also true for some non-Cartesian printers, like delta or polar printers, which move easier and faster in a curve.
G2 & G3: Controlled Arc Move
Usage
G2 Xnnn Ynnn Innn Jnnn Ennn Fnnn (Clockwise Arc)
G3 Xnnn Ynnn Innn Jnnn Ennn Fnnn (Counter-Clockwise Arc)
Parameters
Examples
G2 X90.6 Y13.8 I5 J10 E22.4 (Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
G3 X90.6 Y13.8 I5 J10 E22.4 (Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
Notes
1In Marlin Firmware not implemented for DELTA and SCARA printers.
G4: Dwell
Parameters
Pnnn Time to wait, in milliseconds
Snnn Time to wait, in seconds (Only on Repetier, Marlin, Smoothieware, and RepRapFirmware 1.16 and later)
Example
G4 P200
In this case sit still doing nothing for 200 milliseconds. During delays the state of the machine (for example the temperatures of its extruders) will still be preserved and controlled.
On Marlin, Smoothie and RepRapFirmware, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
G6: Direct Stepper Move
Perform a direct, uninterpolated, and non-kinematic synchronized move of one or more steppers directly. Units may be linear (e.g., mm or inches on DELTA) or specified in degrees (SCARA). This command is useful for initialization, diagnostics, and calibration, and should be disabled on production equipment. This type of move can be potentially dangerous, especially for deltabots, so implementations should do their best to limit movement to prevent twerking and damaging the carriage assembly.
Parameters
Annn Stepper A position or angle
Bnnn Stepper B position or angle
Cnnn Stepper C position or angle
R Relative move flag
SCARA Examples
G6 A45 ; Move SCARA A stepper to the 45° position
G6 B20 R ; Move SCARA B stepper 20° counter-clockwise
DELTA Example
G6 C10 R ; Move DELTA C carriage up by 10mm
G10: Tool Offset
Usage
Parameters
Pnnn Tool number
Xnnn X offset
Ynnn Y offset
U,V,Wnnn U, V and W axis offsets5
Znnn Z offset2
Rnnn Standby temperature(s)
Snnn Active temperature(s)
Examples
G10 P2 X17.8 Y-19.3 Z0.0 (sets the offset for tool (or in older implementations extrude head) 2 to the X, Y, and Z values specified)
G10 P1 R140 S205 (set standby and active temperatures3 for tool 1)
Remember that any parameter that you don't specify will automatically be set to the last value for that parameter. That usually means that you want explicitly to set Z0.0. RepRapFirmware will report the tool parameters if only the tool number is specified.
The R value is the standby temperature in oC that will be used for the tool, and the S value is its operating temperature. If you don't want the tool to be at a different temperature when not in use, set both values the same. See the T code (select tool) below. In tools with multiple heaters the temperatures for them all are specified thus: R100.0:90.0:20.0 S185.0:200.0:150.0 .
See also M585.
Notes
1Marlin uses G10/G11 for executing a retraction/unretraction move. The RepRapPro version of Marlin supports G10 for tool offset. Smoothie uses G10 for retract and G10 Ln for setting workspace coordinates.
G10: Retract
Parameters
Snnn retract length (S1 = long retract, S0 = short retract = default) (Repetier only)
Example
G10
Retracts filament according to settings of M207 (Marlin, RepRapFirmware) or according to the S value (Repetier).
RepRapFirmware recognizes G10 as a command to set tool offsets and/or temperatures if the P parameter is present, and as a retraction command if it is absent.
G11: Unretract
Parameters
Example
G11
Unretracts/recovers filament according to settings of M208 (Marlin, RepRapFirmware) or according to the S value (Repetier).
G17..19: Plane Selection (CNC specific)
These codes set the current plane as follows:
  • G17 : XY (default)
  • G18 : ZX
  • G19 : YZ
G20: Set Units to Inches
Example
G20
Units from now on are in inches.
G21: Set Units to Millimeters
Example
G21
Units from now on are in millimeters. (This is the RepRap default.)
G22 & G23: Firmware controlled Retract/Precharge
Usage
G22 ; Retract
G23 ; Unretract/Precharge
G28: Move to Origin (Home)
Parameters
X Flag to go back to the X axis origin
Y Flag to go back to the Y axis origin
Z Flag to go back to the Z axis origin
Examples
G28     ; Home all axes
G28 X Z ; Home the X and Z axes
Notes
G29: Detailed Z-Probe
Usage
G29
G29 Snnn
Parameters
Examples
Manual Bed Leveling Usage
Options for the S parameter
S0 Produces a mesh report
S1 Start probing mesh points
S2 Probe the next mesh point
G29 in Repetier firmware
G29 in RepRapFirmware
RepRapFirmware:
S2 Clear bed height map
To define the grid, see M557.
G29.1: Set Z probe head offset
Example
G29.1 X30 Y20 Z0.5
Example: G29.2 Z0.0
G30: Single Z-Probe
Usage
Parameters
Pnnn Probe point number
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
Hnnn Height correction
Snnn Set parameter
Examples
G30
Examples (RepRapFirmware)
Usage
Parameters
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
E Adjust Endstop
I Adjust Tower
D Adjust Diagonal Rod
T Adjust Tower Radius
Usage
Parameters
Pnnn Trigger value
Xnnn Probe X offset1
Ynnn Probe Y offset1
Znnn Trigger Z height
Cnnn Temperature coefficient2
Snnn Calibration temperature2
Examples
G31 P500 Z2.6
G31 X16.0 Y1.5
Notes
G31: Dock Z Probe sled
Usage
G32
G32 Snnn
Parameters
Examples
G32
G32 S2
Notes
G32: Undock Z Probe sled
Usage
G33
G33 Lnnn
G33 Rnnn
G33 Xnnn Ynnn Znnn
Parameters
R0 Reset distortion matrix
Examples
G33
G33 R0
G38.x Straight Probe (CNC specific)
G54..59: Coordinate System Select (CNC specific)
G60: save current position to slot
Usage
G60 Snn
Parameters
Snn <nn> specifies memory slot # (0-based) to save into (default 0)
G61: Apply/restore saved coordinates to the active extruder.
Usage
Parameters
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
Ennn E coordinate
Fnnn F Set Feedrate
Snn S specifies memory slot # (0-based)
G90: Set to Absolute Positioning
Example: G90
G91: Set to Relative Positioning
Example: G91
G92: Set Position
Parameters
Xnnn new X axis position
Ynnn new Y axis position
Znnn new Z axis position
Ennn new extruder position
Example
G92 X10 E90
  • G92.1 - reset axis offsets to zero and set parameters 5211 - 5219 to zero. (X Y Z A B C U V W)
  • G92.2 - reset axis offsets to zero.
G93: Feed Rate Mode (Inverse Time Mode) (CNC specific)
G94: Feed Rate Mode (Units per Minute) (CNC specific)
Parameters
Rnnn Radius to add
Examples
G130: Set digital potentiometer value
G131: Remove offset
G132: Calibrate endstop offsets
G133: Measure steps to top
G161: Home axes to minimum
Parameters
X Flag to home the X axis to its minimum position
Y Flag to home the Y axis to its minimum position
Z Flag to home the Z axis to its minimum position
Fnnn Desired feedrate for this command
Example
G161 X Y Z F1800
G162: Home axes to maximum
Parameters
X Flag to home the X axis to its maximum position
Y Flag to home the Y axis to its maximum position
Z Flag to home the Z axis to its maximum position
Example
G162 X Y Z F1800
M-commands
Parameters
Example
M0
Notes
2Only available on Marlin.
M1: Sleep or Conditional stop
Example
M1
M2: Program End
Example: M2
Parameters
Snnn Spindle RPM
Example
M3 S4000
Example: M4 S4000
Example: M5
The spindle is turned off.
M6: Tool change
Example: M6
Example: M7
Example: M8
Example: M9
M10: Vacuum On (CNC specific)
Example: M10
Example: M11
Example: M17
Parameters
X X axis
Y Y axis
Z Z axis
E Extruder drive(s)2
Examples
M18
M18 X E0
Notes
M20: List SD card
Parameters
Snnn Output style1
Pnnn Directory to list2
Examples
M20
M20 S2 P/gcodes/subdir
ok
SQUARE.G
SQCOM.G
ZCARRI~2.GCO
CARRIA~1.GCO
Begin file list:
SQUARE.G
ZCARRI~2.GCO
End file list
ok
GCode files:
Notes
M20 S2 P/gcodes
M21: Initialize SD card
Parameters
Examples
M21
M21 P1
M22: Release SD card
Parameters
Examples
M22
M22 P1
M23: Select SD file
Example
M23 filename.gco
M24: Start/resume SD print
Example
M24
M25: Pause SD print
Example
M25
M26: Set SD position
Parameters
Snnn File position in bytes
Example
M26
M27: Report SD print status
Example
M27
Report SD print status.
SD printing byte 2134/235422
Not SD printing.
M28: Begin write to SD card
Example
M28 filename.gco
M29: Stop writing to SD card
Example
M29 filename.gco
Example: M30 filename.gco
filename.gco is deleted.
M30 in grbl
Example
M31
The response looks like:
 echo:54 min, 38 sec
Example
M32 filename.gco
M36: Return file information
Example
M36 filename.gco
M37: Simulation mode
M37 gcodes/myfile.g
Cannot find file
M37 www/reprap.htm
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
M42: Switch I/O pin
Parameters
Pnnn Pin number
Snnn Pin value
Example
M42 P7 S255
P Name Expansion Port Pin
16 TXD1 11
17 RXD1 12
18 TXD0 13
19 RXD0 14
20 TWD1 35
21 TWCK1 36
23 PA14 10
36 PC4 18
52 AD14 41
67 PB16 32
60 PA10/RXD0 14
61 PA11/TXD0 13
62 PA12/RXD1 12
63 PA13/TXD1 11
64 PA14/RTS1 10
65 PB12/TWD1 35
66 PB13/TWCK1 36
67 PB16/DAC1* 32
68 PB21/AD14 41
69 PC4 18
60 CS5 CS5
61 CS6 E3_STOP
62 CS7 E4_STOP
63 CS8 E5_STOP
Pre-1.16 example:
See also M583.
Example: M43
M43: Pin report and debug
Usage
M43 En Pnnn Wn In
Parameters
Parameters
Pnnn number of points
Xnnn position on the X axis
Ynnn position on the Y axis
Vnnn verbosity
E engage
Lnnn legs of travel
M70: Display message
Example:
M70 P200 Message
M72: Play a tone or song
Example: M72 P2
M73: Set build percentage
Example: M73 P50
M80: ATX Power On
Example
M80
M81: ATX Power Off
Example
M81
Example
M82
Example
M83
M84: Stop idle hold
Parameters
Innn Reset flags1
Example
M84
Notes
Example: M85 S30
M92: Set axis_steps_per_unit
Parameters
Examples
M92 X87.489 Y87.489 Z87.489
M92 E420:420
M93: Send axis_steps_per_unit
M98: Call Macro/Subprogram
Parameters
Pnnn Macro filename
Example
M98 Pmymacro.g
Example
M99
Returns from an M98 call.
M98: Get axis_hysteresis_mm
Example: M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Proposed for Marlin
Parameters
Snnn Target temperature
Example
M104 S190
M104 in Teacup Firmware
Example: M104 P1 S100
Parameters
Snnn Response type1
Examples
M105
M105 S2
ok T:201 B:117
M105 X0
Notes
M106: Fan On
Parameters
Extra Parameters
Examples
M106 S127
M106 P1 I1 S871
M106 P1 T45 H1:21
M106 P2 B0.1 L0.051
Notes
M106 in RepRapFirmware
M106 in Teacup Firmware
Example: M106 P2 S255
M107: Fan Off
M108: Cancel Heating (Marlin)
Parameters
Example
M109 S215
M109 in Teacup
Example: M109 S185
M109 in Sprinter (4pi port)
M109 in MakerBot
Example: M109 S70 T0
M110: Set Current Line Number
Parameters
Nnnn Line number
Example
M110 N123
M111: Set Debug Level
Parameters
Pnnn Debug module1
Snnn Debug on/off
Examples
M111 S6
M111 P1 S1
Notes
M111 in RepRapFirmware
M111 in Repetier
#define DEBUG_ECHO (1<<0)
#define DEBUG_INFO (1<<1)
#define DEBUG_ERRORS (1<<2)
M112: Emergency Stop
Example
M112
M113: Set Extruder PWM
Example: M113
M113 S0.7
M114: Get Current Position
Example
M114
Parameters
Pnnn Electronics type1
Examples
M115
M115 P2
sample data from firmware:
Notes
M115 P1   Duet 0.6
M115 P2   Duet 0.7
M115 P3   Duet 0.85
M116: Wait
Parameters
Pnnn Tool number
Hnnn Heater number
Cnnn Chamber number
Examples
M116
M116 P1
Notes
M117: Get Zero Position
Example: M117
M117: Display Message
Example
M117 Hello World
M118: Negotiate Features
Example: M118 P42
M119: Get Endstop Status
Example
M119
Example
M119 X1 1
M120: Push
Example
M120
  1. Current feedrate, and
  1. Current feedrate
  2. Extruder positions
M121: Pop
Example
M121
M122: Diagnose
Example
M122
M123: Tachometer value
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
Example: M126 P500
M126 in MakerBot
Example: M126 T0
M127: Close Valve
Example: M127 P400
M127 in MakerBot
Example: M127 T0
M128: Extruder Pressure PWM
Example: M128 S255
M129: Extruder pressure off
Example: M129 P100
M130: Set PID P value
Parameters
Pnnn heater number
Snnn proportional (Kp)
Example
M131: Set PID I value
Parameters
Pnnn heater number
Snnn integral (Ki)
Example
M132: Set PID D value
Parameters
Pnnn heater number
Snnn derivative (Kd)
Example
M132 in MakerBot
Example: M132 X Y Z A B
M133: Set PID I limit value
Parameters
Pnnn heater number
Snnn integral limit (Ki)
Example
M133 in MakerBot
Example: M133 T0 P500
Example: M134
M134 in MakerBot
Example: M134 T0 P500
M135: Set PID sample interval
Parameters
Example
M135 S300
M135 in MakerBot
Example: M135 T0
Parameters
Hnnn Heater number1
Example
M140 S55
M140 S-273.15
Parameters
Hnnn Heater number1
Examples
M141 S30
M141 H0
Notes
M142: Holding Pressure
Example: M142 S1
Example: M143 S275
M144: Bed Standby
Example
M144
M146: Set Chamber Humidity
Parameters
Example
M146 R60
M149: Set temperature units
Parameters
Example
M149 K
M150: Set display color
Parameters
Rnnn red
Unnn green
Bnnn blue
Example
M150 R255 U128 B192
Parameters
Example
M155 S1
Cap:AUTOREPORT_TEMP:1
Example: M160 S4
M160 S4
G1 X70.6 E0:0:0:42.4
G1 E42.4:0:0:0
Parameters
Snnn extruder number
Pnnn weight
M164: Store weights
Parameters
Snnn virtual extruder number
Parameters ABCDHI
Parameters
Example
M190 S60
Example: M191 P60
M200: Set filament diameter
Parameters
Xnnn Acceleration for X axis
Ynnn Acceleration for Y axis
Znnn Acceleration for Z axis
Example
M201 X1000 Y1000 Z100 E2000
M203: Set maximum feedrate
Parameters
Example
M203 X6000 Y6000 Z300 E10000
M203 Repetier
Set temperture monitor to Sx.
P = Printing moves
M204 Repetier
M204 X[Kp] Y[Ki] Z[Kd] -
M205: Advanced settings
Sprinter and Marlin:
Sprinter / Marlin Example:
Smoothie example:
M205 Repetier
Output EEPROM settings.
M206: Offset axes
Parameters
Xnnn X axis offset
Ynnn Y axis offset
Znnn Z axis offset
Example
M206 X10.0 Y10.0 Z-0.4
Example: M206 T3 P39 X19.9
Set Jerk to 19.9
Example: M207
M207: Set retract length
Parameters
Znnn additional zlift/hop
Example
M207 S4.0 F2400 Z0.075
M208: Set axis max travel
Parameters
Xnnn X axis limit
Ynnn Y axis limit
Znnn Z axis limit
Example
M208 X250 Y210 Z180
Notes
M208: Set unretract length
Parameters
Fnnn feedrate, in mm/sec
Example: M209 S1
M210: Set homing feedrates
Example: M210 X1000 Y1500
Example: M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example: M211 X0 S1
Enables X min endstop
Example: M211
Example: M212 Z-0.2
M218: Set Hotend Offset
Example: M218 T1 X50 Y0.5
Parameters
Example
M220 S80
Parameters
Example
M221 S70
M221 S95 D1
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
Example
M226
M226: Wait for pin state
Parameters
Pnnn pin number
Snnn pin state
Example
M226 P2 S1
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
M231: Set OPS parameter
M240: Trigger camera
Example: M240
Example: M240
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
M250: Set LCD contrast
Example: M250 C20
M260: i2c Send Data
Examples
M260 B77  ; M
M260 B97  ; a
M260 B114 ; r
M260 B108 ; l
M260 B105 ; i
M260 B110 ; n
M261: i2c Request Data
Example
M280: Set servo position
Set servo position absolute.
Parameters
Pnnn Servo index
Snnn Angle or microseconds
Example
M280 P1 S50
M300: Play beep sound
Parameters
Snnn frequency in Hz
Pnnn duration in milliseconds
Example
M300 S300 P1000
M301: Set PID parameters
Parameters
Pnnn proportional (Kp)
Innn integral (Ki)
Dnnn derivative (Kd)
Examples
M301 H1 P1 I2 D3 ; Marlin
Marlin
I: Integral value
D: Derivative value
Smoothie
Other implementations
M301 W125
Teacup
M302: Allow cold extrudes
Parameters
Examples (RepRapFirmwre)
M302 ; Report current state
Examples (Others)
Notes
M303: Run PID tuning
Hot end usage:
M303 S<temperature> C<cycles>
M303 P1 S<temperature>
Bed usage (others):
Example:
M303 C8 S175
M303 E0 S190
Notes
Parameters
Innn integral (Ki)
Examples
M304 ; Report parameters
Parameters
Pnnn Heater number
Rnnn Series resistor value
Lnnn ADC low offset
Hnnn ADC high offset
Example
M305 P1 T100000 R1000 B4200
Example: M306 Z0
Implemented in Smoothieware
Parameters
Dnnn Dead time in seconds
Examples
Usage
M320
M320 S1
Parameters
Examples
Parameter Snnn is optional.
(Repetier only)
Usage
M321
M321 S1
Parameters
Examples
(Repetier only)
Usage
M322
M322 S1
Parameters
Examples
(Repetier only)
Usage
M323
M323 Snnn
M323 Snnn Pnnn
Parameters
Examples
M340: Control the servos
M350: Set microstepping mode
Sets microstepping mode.
Usage
M350 Snn Xnn Ynn Znn Enn Bnn
Parameters
Modes (nn)
1 = full step
2 = half step
4 = quarter step
8 = 1/8 step
16 = 1/16 step
64 = 1/64 step
128 = 1/128 step
256 = 1/256 step
Examples
Example: M351
M355: Turn case lights on/off
Examples
M355 S1 ; Enable lights
M355 S0 ; Disable lights
M355 ; Report status
Case lights on
Case lights off
No case lights
Target
Example
M360
Response
Config:Baudrate:250000
Config:InputBuffer:127
Config:NumExtruder:2
Config:MixingExtruder:0
Config:HeatedBed:0
Config:SDCard:1
Config:Fan:1
Config:LCD:1
Config:SoftwarePowerSwitch:1
Config:XHomeDir:-1
Config:YHomeDir:-1
Config:ZHomeDir:-1
Config:SupportG10G11:1
Config:CaseLights:0
Config:ZProbe:1
Config:Autolevel:0
Config:EEPROM:1
Config:PrintlineCache:24
Config:JerkXY:30.00
Config:JerkZ:0.30
Config:RetractionLength:3.00
Config:RetractionSpeed:40.00
Config:RetractionZLift:0.00
Config:XMin:0.00
Config:YMin:0.00
Config:ZMin:0.00
Config:XMax:250.00
Config:YMax:150.00
Config:ZMax:90.00
Config:XSize:250.00
Config:YSize:150.00
Config:ZSize:90.00
Config:XPrintAccel:250.00
Config:YPrintAccel:250.00
Config:ZPrintAccel:100.00
Config:XTravelAccel:250.00
Config:YTravelAccel:250.00
Config:ZTravelAccel:100.00
Config:PrinterType:Cartesian
Config:MaxBedTemp:120
Config:Extr.1:Jerk:50.00
Config:Extr.1:MaxSpeed:100.00
Config:Extr.1:Diameter:0.00
Config:Extr.1:MaxTemp:220
Config:Extr.2:Jerk:50.00
Config:Extr.2:MaxSpeed:100.00
Config:Extr.2:Diameter:0.00
Config:Extr.2:MaxTemp:220
M365: SCARA scaling factor
M366: SCARA convert trim
Usage
M370
M374: Save calibration grid
Usage
M374
M374 <file extension> Z
Usage
M375
M375 <file extension>
M380: Activate solenoid
Example: M380
M381: Disable all solenoids
Example: M381
Example
M400
M401: Lower z-probe
Example: M401
Lower z-probe if present.
M402: Raise z-probe
Example: M402
Raise z-probe if present.
Parameters
Nnnn Filament width (in mm)
Dnnn Nozzle diameter (in mm)1
Examples
M404 N1.75
M404 N3.0 D1.0
Notes
M405: Filament Sensor on
Example: M405
M406: Filament Sensor off
Example: M406
Example
M407
Parameters
Snnn Response type
Example
M408 S0
probe:   the Z-probe reading
fanRPM:  the cooling fan RPM
Example: M420 R255 E255 B255
Example: M420 S1
M450: Report Printer Mode
Usage: M450
PrinterMode:FFF
PrinterMode:Laser
PrinterMode:CNC
M451: Select FFF Printer Mode
Usage
M451
Example
M451
Output
PrinterMode:FFF
Usage
M452
Example
M452
Output
PrinterMode:Laser
M453: Select CNC Printer Mode
Usage
M453
Example
M453
Output
PrinterMode:CNC
Usage
M460 X<minTemp> Y<maxTemp>
Example
M460 X50 Y60
Example
M500
Parameters
Example
M501
Example
M502
M503: Print settings
Example
M503
M530: Enable printing mode
Example
M530 S1 L270
Cap:PROGRESS:1
M531: Set print name
Example
M531 Demo Model
M532: Set print progress
Example
M532 X23.7 L56
Parameters
Example
M540 S1
M540: Set MAC address
Parameters
Pnnn The MAC address
Examples
M540 PDE:AD:BE:EF:CA:FE
M550: Set Name
Parameters
Pnnn Machine name
Example
M550 PGodzilla
M551: Set Password
Parameters
Pnnn Password
Example
M551 Pmy-very-secret-word
M552: Set IP address
Parameters
Pnnn IP address
Rnnn HTTP port (default 80)
Example
M552 P192.168.1.14
M553: Set Netmask
Parameters
Pnnn Net mask
Example
M553 P255.255.255.0
M554: Set Gateway
Parameters
Pnnn Gateway
Example
M554 P192.168.1.1
M555: Set compatibility
Parameters
Pnnn Emulation type
Example
M555 P1
P value Firmware
1 RepRap_Firmware
2 Marlin
3 Teacup
4 Sprinter
5 Repetier
M556: Axis compensation
Parameters
Xnnn Deviation in X direction
Ynnn Deviation in Y direction
Znnn Deviation in Z direction
Example
M556 S100 X0.7 Y-0.2 Z0.6
Pnnn Probe point number
Xnnn X coordinate
Ynnn Y coordinate
Example
M557 P1 X30 Y40.5
R Radius to probe
S Probing interval
Examples
M557 X0:200 Y0:220 S20
M557 R150 S15
M558: Set Z probe type
Parameters
Pnnn Z probe type
Xnnn Use probe for X axis
Ynnn Use probe for Y axis
Znnn Use probe for Z axis
Hnnn Dive height1
Example
M558 P0 X1 Y0 Z1
Notes
Example
M559
M560: Upload web page file
Example
M560
<!-- **EoF** -->
M561: Set Identity Transform
Example
M561
M562: Reset temperature fault
Parameters
Pnnn Heater number
Example
M562 P2
M563: Define or remove a tool
Parameters
Pnnn Tool number
Dnnn Extruder drive(s)
Hnnn Heater(s)
Example
G1 X70.6 E0:0:42.4
M563 S1
M563 P1 D-1 H-1
M564: Limit axes
Parameters
Example
M564 S0
M565: Set Z probe offset
Example: M565 X3 Y4.5 Z-2.37
Parameters
Example
M566 X20 Y20 Z2 E10
M567: Set tool mix ratios
Parameters
Pnnn Tool number
Ennn Mix ratios
Example
M567 P2 E0.1:0.2:0.1:0.6
G1 X20 E1.3
See also M568.
Parameters
Pnnn Tool number
Example
M568 P2 S0
G1 X20 E0.2:0.4:0.166:0.3
The off state is the default.
Parameters
Pnnn Motor driver number
Example
M569 P0 S1
Notes
Example
M570 S120
Hnnn Heater number
Example
M570 H1 P4 T15
M571: Set output on extrude
Parameters
Snnn Output value
Example
M571 S0.5
Parameters
Dnnn Extruder number
Example
M572 D0 S0.1
M573: Report heater PWM
Parameters
Pnnn Heater number
Example
M573 P1
Parameters
Xnnn Switch type for X axis
Ynnn Switch type for Y axis
Znnn Switch type for Z axis
Snnn Logic level
Example
M574 X1 Y2 Z0 S1
Parameters
Pnnn Serial channel number
Bnnn Baud rate
Example
M575 P1 B57600 S1
Parameters
Snnn Desired endstop level
Xnnn Select X axis endstop
Ynnn Select Y axis endstop
Znnn Select Z axis endstop
Example
M577 E0 S1
M578: Fire inkjet bits
Parameters
Pnnn Inkjet head number
Snnn Bit pattern
Example
M578 P3 S5
M579: Scale Cartesian axes
Parameters
Xnnn Scale factor for X axis
Ynnn Scale factor for Y axis
Znnn Scale factor for Z axis
Example
M579 X1.0127 Y0.998
M580: Select Roland
Parameters
Example
M580 R1 PVS4;!VZ2;!MC1;
Parameters
Example
M582: Check external trigger
Parameters
T Trigger number to poll
Example
M583: Wait for pin
Parameters
Pnnn Pin number
Example
M584: Set drive mapping
Parameters
Example
M585: Probe Tool
Parameter; one of
Xnnn
Y-nnn
Znnn
So the process should be:
Example
M590
echo: Extruder 0x00
M600: Set line cross section
Example: M600 P0.061
M600: Filament change pause
Example: M600
Example: M605 S1
M665: Set delta configuration
Parameters
Lnnn Diagonal rod length
Rnnn Delta radius
Snnn Segments per second1
Bnnn Safe printing radius2
Examples
M665 L250 R160 S200 (Marlin)
Notes
1Only supported on Marlin.
Parameters
Annn X bed tilt in percent1
Bnnn Y bed tilt in percent1
Example
M666 X-0.1 Y+0.2 Z0
M667: Select CoreXY mode
Parameters
Snnn CoreXY mode
Xnnn X axis scale factor
Ynnn Y axis scale factor
Znnn Z axis scale factor
Example
M667 S1
Typical use would be:
M700: Level plate
Example: M700
M701: Load filament
1 only in bq-Marlin Firmware
Example: M701
M702: Unload filament
Example: M702
M703: Get Board Type
Example: M703
Example: M710
Example: M800
Example: M801
M851: Set Z-Probe Offset
M851 in Marlin 1.0.2
M851 in Marlin 1.1.0
M905: Set local date and time
Parameters
Example
M905 P2016-10-26 S00:23:12
M906: Set motor currents
Parameters
Xnnn X drive motor current
Ynnn Y drive motor current
Znnn Z drive motor current
Example
M906 X300 Y500 Z200 E350:350
Notes
M908 P<pin> S<current>
M909: Set microstepping
Example:
M909 X3 Y5 Z2 E3
M910: Set decay mode
Example:
M910 X3 Y5 Z2 E3
Parameters
Snnn Undervoltage threshold
Tnnn Overvoltage threshold
Example:
M911 P0 S20 T27.5
Parameters
Example:
M912 P0 S10.5
Parameters
Example:
M928: Start SD logging
Example:
M928 filename.g
Stop SD logging with M29.
Parameters
Example
M998: Request resend of line
Parameters
Pnnn Line number
Example
M998 P34
Parameters
Pnnn Reset flags1
Example
M999
Notes
Other commands
G: List all G-codes
Example: G
M: List all M-codes
Example: M
T: Select Tool
Parameters
Tool number
Example
T1
The sequence followed is:
  4. Use the new tool.
  2. (Old tool is released);
Notes
xx can be one of:
ok
rs
// action:command
ok
start
Exceptions:
  • Resend: 8
  • Writing to File: print.gco
  • Done saving file.
  • File selected
  • M105 S2
  • M105 S3
  • M20 S2
  • M36
  • M408
Problem to solve
Alternatives to G-code
