G-коды
- 1 Введение
- 2 Синтаксис (Fields)
- 3 Комментарии
- 4 Специальные символы
- 5 Проверка
- 6 Буферизация
- 7 G-команды
- 7.1 G0 & G1: Перемещение
- 7.3 G4: Ожидание (Пауза)
- 7.5 G10: Смещение инструмента
- 7.7 G11: Докат??? (обратный ретракт)
- 7.13 G29: Detailed Z-Probe
- 7.14 G29.1: Set Z probe head offset
- 7.16 G30: Single Z-Probe
- 7.18 G31: Dock Z Probe sled
- 7.22 G38.x Straight Probe (CNC specific)
- 7.24 G54..59: Coordinate System Select (CNC specific)
- 7.25 G60: save current position to slot
- 7.26 G61: Apply/restore saved coordinates to the active extruder.
- 7.28 G90: Set to Absolute Positioning
- 7.30 G92: Set Position
- 7.35 G131: Remove offset
- 8 M-commands
- 8.3 M2: Program End
- 8.7 M6: Tool change
- 8.15 M20: List SD card
- 8.17 M22: Release SD card
- 8.18 M23: Select SD file
- 8.20 M25: Pause SD print
- 8.21 M26: Set SD position
- 8.33 M37: Simulation mode
- 8.35 M40: Eject
- 8.36 M41: Loop
- 8.37 M42: Switch I/O pin
- 8.41 M70: Display message
- 8.44 M80: ATX Power On
- 8.45 M81: ATX Power Off
- 8.48 M84: Stop idle hold
- 8.61 M106: Fan On
- 8.62 M107: Fan Off
- 8.67 M111: Set Debug Level
- 8.68 M112: Emergency Stop
- 8.69 M113: Set Extruder PWM
- 8.72 M116: Wait
- 8.74 M117: Display Message
- 8.77 M120: Push
- 8.78 M121: Pop
- 8.81 M122: Diagnose
- 8.82 M123: Tachometer value
- 8.84 M126: Open Valve
- 8.85 M127: Close Valve
- 8.88 M130: Set PID P value
- 8.89 M131: Set PID I value
- 8.90 M132: Set PID D value
- 8.97 M142: Holding Pressure
- 8.99 M144: Bed Standby
- 8.106 M164: Store weights
- 8.116 M206: Offset axes
- 8.143 M240: Trigger camera
- 8.146 M245: Start cooler
- 8.147 M246: Stop cooler
- 8.150 M260: i2c Send Data
- 8.153 M300: Play beep sound
- 8.156 M303: Run PID tuning
- 8.187 M401: Lower z-probe
- 8.188 M402: Raise z-probe
- 8.205 M503: Print settings
- 8.207 M531: Set print name
- 8.210 M540: Set MAC address
- 8.211 M550: Set Name
- 8.212 M551: Set Password
- 8.213 M552: Set IP address
- 8.214 M553: Set Netmask
- 8.215 M554: Set Gateway
- 8.225 M564: Limit axes
- 8.240 M580: Select Roland
- 8.243 M583: Wait for pin
- 8.245 M585: Probe Tool
- 8.254 M700: Level plate
- 8.255 M701: Load filament
- 8.256 M702: Unload filament
- 8.257 M703: Get Board Type
- 8.267 M910: Set decay mode
- 9 Other commands
- 13 Alternatives to G-code
Введение
Обозначения:
- {{yes}}
- {{automatic}}
- {{no}}
- {{deprecated}}
Синтаксис (Fields)
| Команда | Описание |
Комментарии
Специальные символы
N: Номер линии
Пример: N123
*: Контрольная сумма
Пример: *71
Проверка
Буферизация
G-команды
- G1 : Линейное перемещение
- Использование
- Parameters
- Пример
- Пояснения
- Использование
- Параметры
- Пример
- Примечание
- Parameters
- Пример
- G4 P200
- Параметры
- Пример SCARA робота
- Пример DELTA робота
- Использование
- Параметры
- Xnnn смещение по оси X
- Ynnn смещение по оси Y
- Znnn смещение по оси Z 2
- Пример
Помните, что любой параметр, который вы не укажете, автоматически установится последнее значение для этого параметра. Это обычно означает, что вы хотите явно установить Z0.0. RepRapFirmware сообщит параметры инструмента, если только номер инструмента указан.
Remember that any parameter that you don't specify will automatically be set to the last value for that parameter. That usually means that you want explicitly to set Z0.0. RepRapFirmware will report the tool parameters if only the tool number is specified.
The R value is the standby temperature in oC that will be used for the tool, and the S value is its operating temperature. If you don't want the tool to be at a different temperature when not in use, set both values the same. See the T code (select tool) below. In tools with multiple heaters the temperatures for them all are specified thus: R100.0:90.0:20.0 S185.0:200.0:150.0 .
Смотрите так же M585.
- Примечания
1Marlin uses G10/G11 for executing a retraction/unretraction move. The RepRapPro version of Marlin supports G10 for tool offset. Smoothie uses G10 for retract and G10 Ln for setting workspace coordinates.
- Параметры
- Пример
- G10
- Параметры
- G11
Unretracts / восстанавливает положение пластика в соответствии с настройками M208 (Marlin, RepRapFirmware) или в соответствии со значением S (Repetier).
- G17 : XY (по умолчанию)
- G18 : ZX
- G19 : YZ
- Пример
- G20
- Пример
- G21
- Usage
- G22 ; Откат
- G23 ; Противооткат/Подача
- Параметры
- Пример
- Notes
- Usage
- G29
- G29 Snnn
- Parameters
- Examples
- Manual Bed Leveling Usage
- Options for the S parameter
- S0 Produces a mesh report
G29 in Repetier firmware
G29 in RepRapFirmware
RepRapFirmware:
- S2 Clear bed height map
To define the grid, see M557.
- Example
G29.1 X30 Y20 Z0.5
Example: G29.2 Z0.0
G30: Single Z-Probe
- Usage
- Parameters
- Pnnn Probe point number
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- Hnnn Height correction
- Snnn Set parameter
- Examples
- G30
- Examples (RepRapFirmware)
- Usage
- Parameters
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- E Adjust Endstop
- I Adjust Tower
- D Adjust Diagonal Rod
- T Adjust Tower Radius
- Usage
- Parameters
- Pnnn Trigger value
- Xnnn Probe X offset1
- Ynnn Probe Y offset1
- Znnn Trigger Z height
- Examples
- G31 P500 Z2.6
- G31 X16.0 Y1.5
- Notes
- Usage
- G32
- G32 Snnn
- Parameters
- Examples
- G32
- G32 S2
- Notes
- Usage
- G33
- G33 Lnnn
- G33 Rnnn
- G33 Xnnn Ynnn Znnn
- Parameters
- R0 Reset distortion matrix
- Examples
- G33
- G33 R0
- Usage
- G60 Snn
- Parameters
- Snn <nn> specifies memory slot # (0-based) to save into (default 0)
- Usage
- Parameters
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- Ennn E coordinate
- Fnnn F Set Feedrate
- Snn S specifies memory slot # (0-based)
Example: G90
Example: G91
G92: Set Position
- Parameters
- Xnnn new X axis position
- Ynnn new Y axis position
- Znnn new Z axis position
- Ennn new extruder position
- Example
- G92 X10 E90
- Parameters
- Rnnn Radius to add
- Examples
G131: Remove offset
- Parameters
- Example
- G161 X Y Z F1800
- Parameters
- Example
- G162 X Y Z F1800
M-commands
- Parameters
- Example
- M0
- Notes
2Only available on Marlin.
- Example
- M1
M2: Program End
Example: M2
- Parameters
- Snnn Spindle RPM
- Example
- M3 S4000
Example: M4 S4000
Example: M5
The spindle is turned off.
M6: Tool change
Example: M6
Example: M7
Example: M8
Example: M9
Example: M10
Example: M11
Example: M17
- Parameters
- X X axis
- Y Y axis
- Z Z axis
- E Extruder drive(s)2
- Examples
- M18
- M18 X E0
- Notes
M20: List SD card
- Parameters
- Snnn Output style1
- Pnnn Directory to list2
- Examples
- M20
- M20 S2 P/gcodes/subdir
- Notes
M20 S2 P/gcodes
- Parameters
- Examples
- M21
- M21 P1
- Parameters
- Examples
- M22
- M22 P1
M23: Select SD file
- Example
- M23 filename.gco
- Example
- M24
M25: Pause SD print
- Example
- M25
- Parameters
- Snnn File position in bytes
- Example
- M26
- Example
- M27
Report SD print status.
SD printing byte 2134/235422
Not SD printing.
- Example
- M28 filename.gco
- Example
- M29 filename.gco
Example: M30 filename.gco
filename.gco is deleted.
M30 in grbl
- Example
- M31
The response looks like:
echo:54 min, 38 sec
- Example
- M32 filename.gco
- Example
- M36 filename.gco
M37 gcodes/myfile.g
Cannot find file
M37 www/reprap.htm
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
M42: Switch I/O pin
- Parameters
- Pnnn Pin number
- Snnn Pin value
- Example
- M42 P7 S255
| 16 | TXD1 | 11 |
| 17 | RXD1 | 12 |
| 18 | TXD0 | 13 |
| 19 | RXD0 | 14 |
| 20 | TWD1 | 35 |
| 21 | TWCK1 | 36 |
| 23 | PA14 | 10 |
| 36 | PC4 | 18 |
| 52 | AD14 | 41 |
| 67 | PB16 | 32 |
| 60 | PA10/RXD0 | 14 |
| 61 | PA11/TXD0 | 13 |
| 62 | PA12/RXD1 | 12 |
| 63 | PA13/TXD1 | 11 |
| 64 | PA14/RTS1 | 10 |
| 65 | PB12/TWD1 | 35 |
| 66 | PB13/TWCK1 | 36 |
| 67 | PB16/DAC1* | 32 |
| 68 | PB21/AD14 | 41 |
| 69 | PC4 | 18 |
| 60 | CS5 | CS5 |
| 61 | CS6 | E3_STOP |
| 62 | CS7 | E4_STOP |
| 63 | CS8 | E5_STOP |
Pre-1.16 example:
See also M583.
Example: M43
M43: Pin report and debug
- Usage
- M43 En Pnnn Wn In
- Parameters
- Parameters
- Pnnn number of points
- Xnnn position on the X axis
- Ynnn position on the Y axis
- Vnnn verbosity
- E engage
- Lnnn legs of travel
M70: Display message
Example:
M70 P200 Message
M72: Play a tone or song
Example: M72 P2
M73: Set build percentage
Example: M73 P50
M80: ATX Power On
- Example
- M80
M81: ATX Power Off
- Example
- M81
- Example
- M82
- Example
- M83
M84: Stop idle hold
- Parameters
- Innn Reset flags1
- Example
- M84
- Notes
Example: M85 S30
M92: Set axis_steps_per_unit
- Parameters
- Examples
- M92 X87.489 Y87.489 Z87.489
- M92 E420:420
M93: Send axis_steps_per_unit
M98: Call Macro/Subprogram
- Parameters
- Pnnn Macro filename
- Example
- M98 Pmymacro.g
- Example
- M99
Returns from an M98 call.
M98: Get axis_hysteresis_mm
Example: M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Proposed for Marlin
- Parameters
- Snnn Target temperature
- Example
- M104 S190
M104 in Teacup Firmware
Example: M104 P1 S100
- Parameters
- Snnn Response type1
- Examples
- M105
- M105 S2
ok T:201 B:117
- Notes
M106: Fan On
- Parameters
- Extra Parameters
- Examples
- M106 S127
- M106 P1 I1 S871
- M106 P1 T45 H1:21
- M106 P2 B0.1 L0.051
- Notes
M106 in RepRapFirmware
M106 in Teacup Firmware
Example: M106 P2 S255
M107: Fan Off
M108: Cancel Heating (Marlin)
- Parameters
- Example
- M109 S215
M109 in Teacup
Example: M109 S185
M109 in Sprinter (4pi port)
M109 in MakerBot
Example: M109 S70 T0
M110: Set Current Line Number
- Parameters
- Nnnn Line number
- Example
- M110 N123
M111: Set Debug Level
- Parameters
- Pnnn Debug module1
- Snnn Debug on/off
- Examples
- M111 S6
- M111 P1 S1
- Notes
M111 in RepRapFirmware
M111 in Repetier
M112: Emergency Stop
- Example
- M112
M113: Set Extruder PWM
Example: M113
M113 S0.7
M114: Get Current Position
- Example
- M114
- Parameters
- Pnnn Electronics type1
- Examples
- M115
- M115 P2
sample data from firmware:
- Notes
M116: Wait
- Parameters
- Pnnn Tool number
- Hnnn Heater number
- Cnnn Chamber number
- Examples
- M116
- M116 P1
- Notes
M117: Get Zero Position
Example: M117
M117: Display Message
- Example
- M117 Hello World
M118: Negotiate Features
Example: M118 P42
M119: Get Endstop Status
- Example
- M119
- Example
- M119 X1 1
M120: Push
- Example
- M120
- Current feedrate, and
- Current feedrate
- Extruder positions
M121: Pop
- Example
- M121
M122: Diagnose
- Example
- M122
M123: Tachometer value
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
Example: M126 P500
M126 in MakerBot
Example: M126 T0
M127: Close Valve
Example: M127 P400
M127 in MakerBot
Example: M127 T0
M128: Extruder Pressure PWM
Example: M128 S255
M129: Extruder pressure off
Example: M129 P100
M130: Set PID P value
- Parameters
- Pnnn heater number
- Snnn proportional (Kp)
- Example
M131: Set PID I value
- Parameters
- Snnn integral (Ki)
- Example
M132: Set PID D value
- Parameters
- Snnn derivative (Kd)
- Example
M132 in MakerBot
Example: M132 X Y Z A B
M133: Set PID I limit value
- Parameters
- Snnn integral limit (Ki)
- Example
M133 in MakerBot
Example: M133 T0 P500
Example: M134
M134 in MakerBot
Example: M134 T0 P500
M135: Set PID sample interval
- Parameters
- Example
- M135 S300
M135 in MakerBot
Example: M135 T0
- Parameters
- Hnnn Heater number1
- Example
- M140 S55
M140 S-273.15
- Parameters
- Examples
- M141 S30
- M141 H0
- Notes
M142: Holding Pressure
Example: M142 S1
Example: M143 S275
M144: Bed Standby
- Example
- M144
M146: Set Chamber Humidity
- Parameters
- Example
- M146 R60
M149: Set temperature units
- Parameters
- Example
- M149 K
M150: Set display color
- Parameters
- Rnnn red
- Unnn green
- Bnnn blue
- Example
- M150 R255 U128 B192
- Parameters
- Example
- M155 S1
Cap:AUTOREPORT_TEMP:1
Example: M160 S4
- Parameters
- Snnn extruder number
- Pnnn weight
M164: Store weights
- Parameters
- Parameters ABCDHI
- Parameters
- Example
- M190 S60
Example: M191 P60
M200: Set filament diameter
- Parameters
- Example
- M201 X1000 Y1000 Z100 E2000
M203: Set maximum feedrate
- Parameters
- Example
M203 Repetier
Set temperture monitor to Sx.
P = Printing moves
M204 Repetier
M204 X[Kp] Y[Ki] Z[Kd] -
M205: Advanced settings
Sprinter and Marlin:
Sprinter / Marlin Example:
Smoothie example:
M205 Repetier
Output EEPROM settings.
M206: Offset axes
- Parameters
- Xnnn X axis offset
- Ynnn Y axis offset
- Znnn Z axis offset
- Example
- M206 X10.0 Y10.0 Z-0.4
Example: M206 T3 P39 X19.9
Set Jerk to 19.9
Example: M207
M207: Set retract length
- Parameters
- Znnn additional zlift/hop
- Example
- M207 S4.0 F2400 Z0.075
M208: Set axis max travel
- Parameters
- Xnnn X axis limit
- Ynnn Y axis limit
- Znnn Z axis limit
- Example
- M208 X250 Y210 Z180
- Notes
M208: Set unretract length
- Parameters
- Fnnn feedrate, in mm/sec
Example: M209 S1
M210: Set homing feedrates
Example: M210 X1000 Y1500
Example: M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example: M211 X0 S1
Enables X min endstop
Example: M211
Example: M212 Z-0.2
M218: Set Hotend Offset
Example: M218 T1 X50 Y0.5
- Parameters
- Example
- M220 S80
- Parameters
- Example
- M221 S70
- M221 S95 D1
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
- Example
- M226
M226: Wait for pin state
- Parameters
- Pnnn pin number
- Snnn pin state
- Example
- M226 P2 S1
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
M231: Set OPS parameter
M240: Trigger camera
Example: M240
Example: M240
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
M250: Set LCD contrast
Example: M250 C20
M260: i2c Send Data
- Examples
M261: i2c Request Data
- Example
M280: Set servo position
Set servo position absolute.
- Parameters
- Pnnn Servo index
- Snnn Angle or microseconds
- Example
- M280 P1 S50
M300: Play beep sound
- Parameters
- Snnn frequency in Hz
- Example
- M300 S300 P1000
M301: Set PID parameters
- Parameters
- Pnnn proportional (Kp)
- Innn integral (Ki)
- Dnnn derivative (Kd)
- Examples
- M301 H1 P1 I2 D3 ; Marlin
Marlin
I: Integral value
D: Derivative value
Smoothie
Other implementations
- M301 W125
Teacup
M302: Allow cold extrudes
- Parameters
- Examples (RepRapFirmwre)
- M302 ; Report current state
- Examples (Others)
- Notes
M303: Run PID tuning
Hot end usage:
M303 S<temperature> C<cycles>
M303 P1 S<temperature>
Bed usage (others):
Example:
M303 C8 S175
M303 E0 S190
- Notes
- Parameters
- Examples
- M304 ; Report parameters
- Parameters
- Pnnn Heater number
- Rnnn Series resistor value
- Lnnn ADC low offset
- Hnnn ADC high offset
- Example
- M305 P1 T100000 R1000 B4200
Example: M306 Z0
Implemented in Smoothieware
- Parameters
- Dnnn Dead time in seconds
- Examples
- Usage
- M320
- M320 S1
- Parameters
- Examples
Parameter Snnn is optional.
(Repetier only)
- Usage
- M321
- M321 S1
- Parameters
- Examples
(Repetier only)
- Usage
- M322
- M322 S1
- Parameters
- Examples
(Repetier only)
- Usage
- M323
- M323 Snnn
- M323 Snnn Pnnn
- Parameters
- Examples
M340: Control the servos
M350: Set microstepping mode
Sets microstepping mode.
- Usage
- Parameters
- Modes (nn)
- 1 = full step
- 2 = half step
- 4 = quarter step
- 8 = 1/8 step
- 16 = 1/16 step
- 64 = 1/64 step
- 128 = 1/128 step
- 256 = 1/256 step
- Examples
Example: M351
M355: Turn case lights on/off
- Examples
- M355 S1 ; Enable lights
- M355 S0 ; Disable lights
- M355 ; Report status
- Target
- Example
- M360
- Response
M365: SCARA scaling factor
M366: SCARA convert trim
- Usage
- M370
M374: Save calibration grid
- Usage
- M374
- M374 <file extension> Z
- Usage
- M375
- M375 <file extension>
M380: Activate solenoid
Example: M380
M381: Disable all solenoids
Example: M381
- Example
- M400
M401: Lower z-probe
Example: M401
Lower z-probe if present.
M402: Raise z-probe
Example: M402
Raise z-probe if present.
- Parameters
- Nnnn Filament width (in mm)
- Examples
- M404 N1.75
- M404 N3.0 D1.0
- Notes
M405: Filament Sensor on
Example: M405
M406: Filament Sensor off
Example: M406
- Example
- M407
- Parameters
- Snnn Response type
- Example
- M408 S0
probe: the Z-probe reading
fanRPM: the cooling fan RPM
Example: M420 R255 E255 B255
Example: M420 S1
M450: Report Printer Mode
Usage: M450
- PrinterMode:FFF
- PrinterMode:Laser
- PrinterMode:CNC
M451: Select FFF Printer Mode
- Usage
- M451
- Example
- M451
- Output
- PrinterMode:FFF
- Usage
- M452
- Example
- M452
- Output
- PrinterMode:Laser
M453: Select CNC Printer Mode
- Usage
- M453
- Example
- M453
- Output
- PrinterMode:CNC
- Usage
- M460 X<minTemp> Y<maxTemp>
- Example
- M460 X50 Y60
- Example
- M500
- Parameters
- Example
- M501
- Example
- M502
M503: Print settings
- Example
- M503
M530: Enable printing mode
- Example
M530 S1 L270
Cap:PROGRESS:1
M531: Set print name
- Example
M531 Demo Model
M532: Set print progress
- Example
- M532 X23.7 L56
- Parameters
- Example
- M540 S1
M540: Set MAC address
- Parameters
- Pnnn The MAC address
- Examples
- M540 PDE:AD:BE:EF:CA:FE
M550: Set Name
- Parameters
- Pnnn Machine name
- Example
- M550 PGodzilla
M551: Set Password
- Parameters
- Pnnn Password
- Example
- M551 Pmy-very-secret-word
M552: Set IP address
- Parameters
- Pnnn IP address
- Rnnn HTTP port (default 80)
- Example
- M552 P192.168.1.14
M553: Set Netmask
- Parameters
- Pnnn Net mask
- Example
- M553 P255.255.255.0
M554: Set Gateway
- Parameters
- Pnnn Gateway
- Example
- M554 P192.168.1.1
M555: Set compatibility
- Parameters
- Pnnn Emulation type
- Example
- M555 P1
| P value | Firmware |
| 1 | RepRap_Firmware |
| 2 | Marlin |
| 3 | Teacup |
| 4 | Sprinter |
| 5 | Repetier |
M556: Axis compensation
- Parameters
- Example
- M556 S100 X0.7 Y-0.2 Z0.6
- Pnnn Probe point number
- Xnnn X coordinate
- Ynnn Y coordinate
- Example
- M557 P1 X30 Y40.5
- R Radius to probe
- S Probing interval
- Examples
- M557 X0:200 Y0:220 S20
- M557 R150 S15
M558: Set Z probe type
- Parameters
- Pnnn Z probe type
- Xnnn Use probe for X axis
- Ynnn Use probe for Y axis
- Znnn Use probe for Z axis
- Hnnn Dive height1
- Example
- M558 P0 X1 Y0 Z1
- Notes
- Example
- M559
M560: Upload web page file
- Example
- M560
<!-- **EoF** -->
M561: Set Identity Transform
- Example
- M561
M562: Reset temperature fault
- Parameters
- Example
- M562 P2
M563: Define or remove a tool
- Parameters
- Pnnn Tool number
- Dnnn Extruder drive(s)
- Hnnn Heater(s)
- Example
M563 S1
M563 P1 D-1 H-1
M564: Limit axes
- Parameters
- Example
- M564 S0
M565: Set Z probe offset
Example: M565 X3 Y4.5 Z-2.37
- Parameters
- Example
- M566 X20 Y20 Z2 E10
M567: Set tool mix ratios
- Parameters
- Pnnn Tool number
- Ennn Mix ratios
- Example
- M567 P2 E0.1:0.2:0.1:0.6
G1 X20 E1.3
See also M568.
- Parameters
- Pnnn Tool number
- Example
- M568 P2 S0
G1 X20 E0.2:0.4:0.166:0.3
The off state is the default.
- Parameters
- Pnnn Motor driver number
- Example
- M569 P0 S1
- Notes
- Example
- M570 S120
- Hnnn Heater number
- Example
- M570 H1 P4 T15
M571: Set output on extrude
- Parameters
- Snnn Output value
- Example
- M571 S0.5
- Parameters
- Dnnn Extruder number
- Example
- M572 D0 S0.1
M573: Report heater PWM
- Parameters
- Example
- M573 P1
- Parameters
- Xnnn Switch type for X axis
- Ynnn Switch type for Y axis
- Znnn Switch type for Z axis
- Snnn Logic level
- Example
- M574 X1 Y2 Z0 S1
- Parameters
- Pnnn Serial channel number
- Bnnn Baud rate
- Example
- M575 P1 B57600 S1
- Parameters
- Snnn Desired endstop level
- Xnnn Select X axis endstop
- Ynnn Select Y axis endstop
- Znnn Select Z axis endstop
- Example
- M577 E0 S1
M578: Fire inkjet bits
- Parameters
- Pnnn Inkjet head number
- Snnn Bit pattern
- Example
- M578 P3 S5
M579: Scale Cartesian axes
- Parameters
- Example
- M579 X1.0127 Y0.998
M580: Select Roland
- Parameters
- Example
- M580 R1 PVS4;!VZ2;!MC1;
- Parameters
- Example
M582: Check external trigger
- Parameters
- T Trigger number to poll
- Example
M583: Wait for pin
- Parameters
- Pnnn Pin number
- Example
M584: Set drive mapping
- Parameters
- Example
M585: Probe Tool
- Parameter; one of
- Xnnn
- Y-nnn
- Znnn
So the process should be:
- Example
- M590
- echo: Extruder 0x00
M600: Set line cross section
Example: M600 P0.061
M600: Filament change pause
Example: M600
Example: M605 S1
M665: Set delta configuration
- Parameters
- Lnnn Diagonal rod length
- Rnnn Delta radius
- Snnn Segments per second1
- Bnnn Safe printing radius2
- Examples
- Notes
1Only supported on Marlin.
- Parameters
- Annn X bed tilt in percent1
- Bnnn Y bed tilt in percent1
- Example
- M666 X-0.1 Y+0.2 Z0
M667: Select CoreXY mode
- Parameters
- Snnn CoreXY mode
- Xnnn X axis scale factor
- Ynnn Y axis scale factor
- Znnn Z axis scale factor
- Example
- M667 S1
Typical use would be:
M700: Level plate
Example: M700
M701: Load filament
1 only in bq-Marlin Firmware
Example: M701
M702: Unload filament
Example: M702
M703: Get Board Type
Example: M703
Example: M710
Example: M800
Example: M801
M851: Set Z-Probe Offset
M851 in Marlin 1.0.2
M851 in Marlin 1.1.0
M905: Set local date and time
- Parameters
- Example
- M905 P2016-10-26 S00:23:12
M906: Set motor currents
- Parameters
- Xnnn X drive motor current
- Ynnn Y drive motor current
- Znnn Z drive motor current
- Example
- Notes
M908 P<pin> S<current>
M909: Set microstepping
Example:
M909 X3 Y5 Z2 E3
M910: Set decay mode
Example:
M910 X3 Y5 Z2 E3
- Parameters
- Snnn Undervoltage threshold
- Tnnn Overvoltage threshold
Example:
M911 P0 S20 T27.5
- Parameters
Example:
M912 P0 S10.5
- Parameters
Example:
M928: Start SD logging
Example:
M928 filename.g
Stop SD logging with M29.
- Parameters
- Example
M998: Request resend of line
- Parameters
- Pnnn Line number
- Example
- M998 P34
- Parameters
- Pnnn Reset flags1
- Example
- M999
- Notes
Other commands
G: List all G-codes
Example: G
M: List all M-codes
Example: M
T: Select Tool
- Parameters
- Tool number
- Example
- T1
The sequence followed is:
- Use the new tool.
- (Old tool is released);
- (New tool is selected); and
- Notes
xx can be one of:
ok
rs
// action:command
ok
start
Exceptions:
- Resend: 8
- Writing to File: print.gco
- Done saving file.
- File selected
- M105 S2
- M105 S3
- M20 S2
- M36
- M408
Problem to solve
Alternatives to G-code
