G-коды
- 1 Введение
- 2 Синтаксис (Fields)
- 3 Комментарии
- 4 Специальные символы
- 5 Проверка
- 6 Буферизация
- 7 G-команды
- 7.1 G0 & G1: Перемещение
- 7.3 G4: Ожидание (Пауза)
- 7.7 G11: Подача
- 7.13 G29: Detailed Z-Probe
- 7.16 G30: Single Z-Probe
- 7.18 G31: Dock Z Probe sled
- 7.28 G90: Установка абсолютной позиции
- 7.35 G131: Удалить смещения
- 8 M-commands
- 8.3 M2: Program End
- 8.7 M6: Tool change
- 8.15 M20: List SD card
- 8.17 M22: Release SD card
- 8.18 M23: Select SD file
- 8.20 M25: Pause SD print
- 8.21 M26: Set SD position
- 8.33 M37: Simulation mode
- 8.35 M40: Eject
- 8.36 M41: Loop
- 8.37 M42: Switch I/O pin
- 8.41 M70: Display message
- 8.44 M80: ATX Power On
- 8.45 M81: ATX Power Off
- 8.48 M84: Stop idle hold
- 8.61 M106: Fan On
- 8.62 M107: Fan Off
- 8.67 M111: Set Debug Level
- 8.68 M112: Emergency Stop
- 8.69 M113: Set Extruder PWM
- 8.72 M116: Wait
- 8.74 M117: Display Message
- 8.77 M120: Push
- 8.78 M121: Pop
- 8.81 M122: Diagnose
- 8.82 M123: Tachometer value
- 8.84 M126: Open Valve
- 8.85 M127: Close Valve
- 8.88 M130: Set PID P value
- 8.89 M131: Set PID I value
- 8.90 M132: Set PID D value
- 8.97 M142: Holding Pressure
- 8.99 M144: Bed Standby
- 8.106 M164: Store weights
- 8.116 M206: Offset axes
- 8.143 M240: Trigger camera
- 8.146 M245: Start cooler
- 8.147 M246: Stop cooler
- 8.150 M260: i2c Send Data
- 8.153 M300: Play beep sound
- 8.156 M303: Run PID tuning
- 8.187 M401: Lower z-probe
- 8.188 M402: Raise z-probe
- 8.205 M503: Print settings
- 8.207 M531: Set print name
- 8.210 M540: Set MAC address
- 8.211 M550: Set Name
- 8.212 M551: Set Password
- 8.213 M552: Set IP address
- 8.214 M553: Set Netmask
- 8.215 M554: Set Gateway
- 8.225 M564: Limit axes
- 8.240 M580: Select Roland
- 8.243 M583: Wait for pin
- 8.245 M585: Probe Tool
- 8.254 M700: Level plate
- 8.255 M701: Load filament
- 8.256 M702: Unload filament
- 8.257 M703: Get Board Type
- 8.267 M910: Set decay mode
- 9 Other commands
- 13 Alternatives to G-code
Введение
Обозначения:
- {{yes}}
- {{automatic}}
- {{no}}
- {{deprecated}}
Синтаксис (Fields)
| Команда | Описание |
Комментарии
Специальные символы
N: Номер линии
Пример: N123
*: Контрольная сумма
Пример: *71
Проверка
Буферизация
G-команды
- G1 : Линейное перемещение
- Использование
- Parameters
- Пример
- Пояснения
- Использование
- Параметры
- Пример
- Примечание
- Parameters
- Пример
- G4 P200
- Параметры
- Пример SCARA робота
- Пример DELTA робота
- Использование
- Параметры
- Xnnn смещение по оси X
- Ynnn смещение по оси Y
- Znnn смещение по оси Z 2
- Пример
Смотрите так же M585.
- Примечания
- Параметры
- Пример
- G10
G11: Подача
- Параметры
- G11
- G17 : XY (по умолчанию)
- G18 : ZX
- G19 : YZ
- Пример
- G20
- Пример
- G21
- Usage
- G22 ; Откат
- G23 ; Противооткат/Подача
- Параметры
- Пример
- Notes
- Usage
- G29
- G29 Snnn
- Parameters
- Examples
- Manual Bed Leveling Usage
- Options for the S parameter
- S0 Produces a mesh report
G29 in Repetier firmware
G29 in RepRapFirmware
RepRapFirmware:
- S2 Clear bed height map
To define the grid, see M557.
- Пример
G29.1 X30 Y20 Z0.5
Example: G29.2 Z0.0
G30: Single Z-Probe
- Usage
- Parameters
- Pnnn Probe point number
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- Hnnn Height correction
- Snnn Set parameter
- Examples
- G30
- Examples (RepRapFirmware)
- Usage
- Parameters
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- E Adjust Endstop
- I Adjust Tower
- D Adjust Diagonal Rod
- T Adjust Tower Radius
- Usage
- Parameters
- Pnnn Trigger value
- Xnnn Probe X offset1
- Ynnn Probe Y offset1
- Znnn Trigger Z height
- Examples
- G31 P500 Z2.6
- G31 X16.0 Y1.5
- Notes
- Usage
- G32
- G32 Snnn
- Parameters
- Examples
- G32
- G32 S2
- Notes
- Usage
- G33
- G33 Lnnn
- G33 Rnnn
- G33 Xnnn Ynnn Znnn
- Parameters
- R0 Reset distortion matrix
- Examples
- G33
- G33 R0
- Применение
- G60 Snn
- Парамтеры
- Использование
- Параметры
- Xnnn X координата
- Ynnn Y координата
- Znnn Z координата
- Ennn E координата
Пример: G90
Example: G91
- Параметры
- Xnnn новая координата X
- Ynnn новая координата Y
- Znnn новая координата Z
- Пример
- G92 X10 E90
- Parameters
- Rnnn Radius to add
- Examples
- Параметры
- Пример
- G161 X Y Z F1800
- Parameters
- Example
- G162 X Y Z F1800
M-commands
- Parameters
- Example
- M0
- Notes
2Only available on Marlin.
- Example
- M1
M2: Program End
Example: M2
- Parameters
- Snnn Spindle RPM
- Example
- M3 S4000
Example: M4 S4000
Example: M5
The spindle is turned off.
M6: Tool change
Example: M6
Example: M7
Example: M8
Example: M9
Example: M10
Example: M11
Example: M17
- Parameters
- X X axis
- Y Y axis
- Z Z axis
- E Extruder drive(s)2
- Examples
- M18
- M18 X E0
- Notes
M20: List SD card
- Parameters
- Snnn Output style1
- Pnnn Directory to list2
- Examples
- M20
- M20 S2 P/gcodes/subdir
- Notes
M20 S2 P/gcodes
- Parameters
- Examples
- M21
- M21 P1
- Parameters
- Examples
- M22
- M22 P1
M23: Select SD file
- Example
- M23 filename.gco
- Example
- M24
M25: Pause SD print
- Example
- M25
- Parameters
- Snnn File position in bytes
- Example
- M26
- Example
- M27
Report SD print status.
SD printing byte 2134/235422
Not SD printing.
- Example
- M28 filename.gco
- Example
- M29 filename.gco
Example: M30 filename.gco
filename.gco is deleted.
M30 in grbl
- Example
- M31
The response looks like:
echo:54 min, 38 sec
- Example
- M32 filename.gco
- Example
- M36 filename.gco
M37 gcodes/myfile.g
Cannot find file
M37 www/reprap.htm
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
M42: Switch I/O pin
- Parameters
- Pnnn Pin number
- Snnn Pin value
- Example
- M42 P7 S255
| 16 | TXD1 | 11 |
| 17 | RXD1 | 12 |
| 18 | TXD0 | 13 |
| 19 | RXD0 | 14 |
| 20 | TWD1 | 35 |
| 21 | TWCK1 | 36 |
| 23 | PA14 | 10 |
| 36 | PC4 | 18 |
| 52 | AD14 | 41 |
| 67 | PB16 | 32 |
| 60 | PA10/RXD0 | 14 |
| 61 | PA11/TXD0 | 13 |
| 62 | PA12/RXD1 | 12 |
| 63 | PA13/TXD1 | 11 |
| 64 | PA14/RTS1 | 10 |
| 65 | PB12/TWD1 | 35 |
| 66 | PB13/TWCK1 | 36 |
| 67 | PB16/DAC1* | 32 |
| 68 | PB21/AD14 | 41 |
| 69 | PC4 | 18 |
| 60 | CS5 | CS5 |
| 61 | CS6 | E3_STOP |
| 62 | CS7 | E4_STOP |
| 63 | CS8 | E5_STOP |
Pre-1.16 example:
See also M583.
Example: M43
M43: Pin report and debug
- Usage
- M43 En Pnnn Wn In
- Parameters
- Parameters
- Pnnn number of points
- Xnnn position on the X axis
- Ynnn position on the Y axis
- Vnnn verbosity
- E engage
- Lnnn legs of travel
M70: Display message
Example:
M70 P200 Message
M72: Play a tone or song
Example: M72 P2
M73: Set build percentage
Example: M73 P50
M80: ATX Power On
- Example
- M80
M81: ATX Power Off
- Example
- M81
- Example
- M82
- Example
- M83
M84: Stop idle hold
- Parameters
- Innn Reset flags1
- Example
- M84
- Notes
Example: M85 S30
M92: Set axis_steps_per_unit
- Parameters
- Examples
- M92 X87.489 Y87.489 Z87.489
- M92 E420:420
M93: Send axis_steps_per_unit
M98: Call Macro/Subprogram
- Parameters
- Pnnn Macro filename
- Example
- M98 Pmymacro.g
- Example
- M99
Returns from an M98 call.
M98: Get axis_hysteresis_mm
Example: M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Proposed for Marlin
- Parameters
- Snnn Target temperature
- Example
- M104 S190
M104 in Teacup Firmware
Example: M104 P1 S100
- Parameters
- Snnn Response type1
- Examples
- M105
- M105 S2
ok T:201 B:117
- Notes
M106: Fan On
- Parameters
- Extra Parameters
- Examples
- M106 S127
- M106 P1 I1 S871
- M106 P1 T45 H1:21
- M106 P2 B0.1 L0.051
- Notes
M106 in RepRapFirmware
M106 in Teacup Firmware
Example: M106 P2 S255
M107: Fan Off
M108: Cancel Heating (Marlin)
- Parameters
- Example
- M109 S215
M109 in Teacup
Example: M109 S185
M109 in Sprinter (4pi port)
M109 in MakerBot
Example: M109 S70 T0
M110: Set Current Line Number
- Parameters
- Nnnn Line number
- Example
- M110 N123
M111: Set Debug Level
- Parameters
- Pnnn Debug module1
- Snnn Debug on/off
- Examples
- M111 S6
- M111 P1 S1
- Notes
M111 in RepRapFirmware
M111 in Repetier
M112: Emergency Stop
- Example
- M112
M113: Set Extruder PWM
Example: M113
M113 S0.7
M114: Get Current Position
- Example
- M114
- Parameters
- Pnnn Electronics type1
- Examples
- M115
- M115 P2
sample data from firmware:
- Notes
M116: Wait
- Parameters
- Pnnn Tool number
- Hnnn Heater number
- Cnnn Chamber number
- Examples
- M116
- M116 P1
- Notes
M117: Get Zero Position
Example: M117
M117: Display Message
- Example
- M117 Hello World
M118: Negotiate Features
Example: M118 P42
M119: Get Endstop Status
- Example
- M119
- Example
- M119 X1 1
M120: Push
- Example
- M120
- Current feedrate, and
- Current feedrate
- Extruder positions
M121: Pop
- Example
- M121
M122: Diagnose
- Example
- M122
M123: Tachometer value
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
Example: M126 P500
M126 in MakerBot
Example: M126 T0
M127: Close Valve
Example: M127 P400
M127 in MakerBot
Example: M127 T0
M128: Extruder Pressure PWM
Example: M128 S255
M129: Extruder pressure off
Example: M129 P100
M130: Set PID P value
- Parameters
- Pnnn heater number
- Snnn proportional (Kp)
- Example
M131: Set PID I value
- Parameters
- Snnn integral (Ki)
- Example
M132: Set PID D value
- Parameters
- Snnn derivative (Kd)
- Example
M132 in MakerBot
Example: M132 X Y Z A B
M133: Set PID I limit value
- Parameters
- Snnn integral limit (Ki)
- Example
M133 in MakerBot
Example: M133 T0 P500
Example: M134
M134 in MakerBot
Example: M134 T0 P500
M135: Set PID sample interval
- Parameters
- Example
- M135 S300
M135 in MakerBot
Example: M135 T0
- Parameters
- Hnnn Heater number1
- Example
- M140 S55
M140 S-273.15
- Parameters
- Examples
- M141 S30
- M141 H0
- Notes
M142: Holding Pressure
Example: M142 S1
Example: M143 S275
M144: Bed Standby
- Example
- M144
M146: Set Chamber Humidity
- Parameters
- Example
- M146 R60
M149: Set temperature units
- Parameters
- Example
- M149 K
M150: Set display color
- Parameters
- Rnnn red
- Unnn green
- Bnnn blue
- Example
- M150 R255 U128 B192
- Parameters
- Example
- M155 S1
Cap:AUTOREPORT_TEMP:1
Example: M160 S4
- Parameters
- Snnn extruder number
- Pnnn weight
M164: Store weights
- Parameters
- Parameters ABCDHI
- Parameters
- Example
- M190 S60
Example: M191 P60
M200: Set filament diameter
- Parameters
- Example
- M201 X1000 Y1000 Z100 E2000
M203: Set maximum feedrate
- Parameters
- Example
M203 Repetier
Set temperture monitor to Sx.
P = Printing moves
M204 Repetier
M204 X[Kp] Y[Ki] Z[Kd] -
M205: Advanced settings
Sprinter and Marlin:
Sprinter / Marlin Example:
Smoothie example:
M205 Repetier
Output EEPROM settings.
M206: Offset axes
- Parameters
- Xnnn X axis offset
- Ynnn Y axis offset
- Znnn Z axis offset
- Example
- M206 X10.0 Y10.0 Z-0.4
Example: M206 T3 P39 X19.9
Set Jerk to 19.9
Example: M207
M207: Set retract length
- Parameters
- Znnn additional zlift/hop
- Example
- M207 S4.0 F2400 Z0.075
M208: Set axis max travel
- Parameters
- Xnnn X axis limit
- Ynnn Y axis limit
- Znnn Z axis limit
- Example
- M208 X250 Y210 Z180
- Notes
M208: Set unretract length
- Parameters
- Fnnn feedrate, in mm/sec
Example: M209 S1
M210: Set homing feedrates
Example: M210 X1000 Y1500
Example: M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example: M211 X0 S1
Enables X min endstop
Example: M211
Example: M212 Z-0.2
M218: Set Hotend Offset
Example: M218 T1 X50 Y0.5
- Parameters
- Example
- M220 S80
- Parameters
- Example
- M221 S70
- M221 S95 D1
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
- Example
- M226
M226: Wait for pin state
- Parameters
- Pnnn pin number
- Snnn pin state
- Example
- M226 P2 S1
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
M231: Set OPS parameter
M240: Trigger camera
Example: M240
Example: M240
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
M250: Set LCD contrast
Example: M250 C20
M260: i2c Send Data
- Examples
M261: i2c Request Data
- Example
M280: Set servo position
Set servo position absolute.
- Parameters
- Pnnn Servo index
- Snnn Angle or microseconds
- Example
- M280 P1 S50
M300: Play beep sound
- Parameters
- Snnn frequency in Hz
- Example
- M300 S300 P1000
M301: Set PID parameters
- Parameters
- Pnnn proportional (Kp)
- Innn integral (Ki)
- Dnnn derivative (Kd)
- Examples
- M301 H1 P1 I2 D3 ; Marlin
Marlin
I: Integral value
D: Derivative value
Smoothie
Other implementations
- M301 W125
Teacup
M302: Allow cold extrudes
- Parameters
- Examples (RepRapFirmwre)
- M302 ; Report current state
- Examples (Others)
- Notes
M303: Run PID tuning
Hot end usage:
M303 S<temperature> C<cycles>
M303 P1 S<temperature>
Bed usage (others):
Example:
M303 C8 S175
M303 E0 S190
- Notes
- Parameters
- Examples
- M304 ; Report parameters
- Parameters
- Pnnn Heater number
- Rnnn Series resistor value
- Lnnn ADC low offset
- Hnnn ADC high offset
- Example
- M305 P1 T100000 R1000 B4200
Example: M306 Z0
Implemented in Smoothieware
- Parameters
- Dnnn Dead time in seconds
- Examples
- Usage
- M320
- M320 S1
- Parameters
- Examples
Parameter Snnn is optional.
(Repetier only)
- Usage
- M321
- M321 S1
- Parameters
- Examples
(Repetier only)
- Usage
- M322
- M322 S1
- Parameters
- Examples
(Repetier only)
- Usage
- M323
- M323 Snnn
- M323 Snnn Pnnn
- Parameters
- Examples
M340: Control the servos
M350: Set microstepping mode
Sets microstepping mode.
- Usage
- Parameters
- Modes (nn)
- 1 = full step
- 2 = half step
- 4 = quarter step
- 8 = 1/8 step
- 16 = 1/16 step
- 64 = 1/64 step
- 128 = 1/128 step
- 256 = 1/256 step
- Examples
Example: M351
M355: Turn case lights on/off
- Examples
- M355 S1 ; Enable lights
- M355 S0 ; Disable lights
- M355 ; Report status
- Target
- Example
- M360
- Response
M365: SCARA scaling factor
M366: SCARA convert trim
- Usage
- M370
M374: Save calibration grid
- Usage
- M374
- M374 <file extension> Z
- Usage
- M375
- M375 <file extension>
M380: Activate solenoid
Example: M380
M381: Disable all solenoids
Example: M381
- Example
- M400
M401: Lower z-probe
Example: M401
Lower z-probe if present.
M402: Raise z-probe
Example: M402
Raise z-probe if present.
- Parameters
- Nnnn Filament width (in mm)
- Examples
- M404 N1.75
- M404 N3.0 D1.0
- Notes
M405: Filament Sensor on
Example: M405
M406: Filament Sensor off
Example: M406
- Example
- M407
- Parameters
- Snnn Response type
- Example
- M408 S0
probe: the Z-probe reading
fanRPM: the cooling fan RPM
Example: M420 R255 E255 B255
Example: M420 S1
M450: Report Printer Mode
Usage: M450
- PrinterMode:FFF
- PrinterMode:Laser
- PrinterMode:CNC
M451: Select FFF Printer Mode
- Usage
- M451
- Example
- M451
- Output
- PrinterMode:FFF
- Usage
- M452
- Example
- M452
- Output
- PrinterMode:Laser
M453: Select CNC Printer Mode
- Usage
- M453
- Example
- M453
- Output
- PrinterMode:CNC
- Usage
- M460 X<minTemp> Y<maxTemp>
- Example
- M460 X50 Y60
- Example
- M500
- Parameters
- Example
- M501
- Example
- M502
M503: Print settings
- Example
- M503
M530: Enable printing mode
- Example
M530 S1 L270
Cap:PROGRESS:1
M531: Set print name
- Example
M531 Demo Model
M532: Set print progress
- Example
- M532 X23.7 L56
- Parameters
- Example
- M540 S1
M540: Set MAC address
- Parameters
- Pnnn The MAC address
- Examples
- M540 PDE:AD:BE:EF:CA:FE
M550: Set Name
- Parameters
- Pnnn Machine name
- Example
- M550 PGodzilla
M551: Set Password
- Parameters
- Pnnn Password
- Example
- M551 Pmy-very-secret-word
M552: Set IP address
- Parameters
- Pnnn IP address
- Rnnn HTTP port (default 80)
- Example
- M552 P192.168.1.14
M553: Set Netmask
- Parameters
- Pnnn Net mask
- Example
- M553 P255.255.255.0
M554: Set Gateway
- Parameters
- Pnnn Gateway
- Example
- M554 P192.168.1.1
M555: Set compatibility
- Parameters
- Pnnn Emulation type
- Example
- M555 P1
| P value | Firmware |
| 1 | RepRap_Firmware |
| 2 | Marlin |
| 3 | Teacup |
| 4 | Sprinter |
| 5 | Repetier |
M556: Axis compensation
- Parameters
- Example
- M556 S100 X0.7 Y-0.2 Z0.6
- Pnnn Probe point number
- Xnnn X coordinate
- Ynnn Y coordinate
- Example
- M557 P1 X30 Y40.5
- R Radius to probe
- S Probing interval
- Examples
- M557 X0:200 Y0:220 S20
- M557 R150 S15
M558: Set Z probe type
- Parameters
- Pnnn Z probe type
- Xnnn Use probe for X axis
- Ynnn Use probe for Y axis
- Znnn Use probe for Z axis
- Hnnn Dive height1
- Example
- M558 P0 X1 Y0 Z1
- Notes
- Example
- M559
M560: Upload web page file
- Example
- M560
<!-- **EoF** -->
M561: Set Identity Transform
- Example
- M561
M562: Reset temperature fault
- Parameters
- Example
- M562 P2
M563: Define or remove a tool
- Parameters
- Pnnn Tool number
- Dnnn Extruder drive(s)
- Hnnn Heater(s)
- Example
M563 S1
M563 P1 D-1 H-1
M564: Limit axes
- Parameters
- Example
- M564 S0
M565: Set Z probe offset
Example: M565 X3 Y4.5 Z-2.37
- Parameters
- Example
- M566 X20 Y20 Z2 E10
M567: Set tool mix ratios
- Parameters
- Pnnn Tool number
- Ennn Mix ratios
- Example
- M567 P2 E0.1:0.2:0.1:0.6
G1 X20 E1.3
See also M568.
- Parameters
- Pnnn Tool number
- Example
- M568 P2 S0
G1 X20 E0.2:0.4:0.166:0.3
The off state is the default.
- Parameters
- Pnnn Motor driver number
- Example
- M569 P0 S1
- Notes
- Example
- M570 S120
- Hnnn Heater number
- Example
- M570 H1 P4 T15
M571: Set output on extrude
- Parameters
- Snnn Output value
- Example
- M571 S0.5
- Parameters
- Dnnn Extruder number
- Example
- M572 D0 S0.1
M573: Report heater PWM
- Parameters
- Example
- M573 P1
- Parameters
- Xnnn Switch type for X axis
- Ynnn Switch type for Y axis
- Znnn Switch type for Z axis
- Snnn Logic level
- Example
- M574 X1 Y2 Z0 S1
- Parameters
- Pnnn Serial channel number
- Bnnn Baud rate
- Example
- M575 P1 B57600 S1
- Parameters
- Snnn Desired endstop level
- Xnnn Select X axis endstop
- Ynnn Select Y axis endstop
- Znnn Select Z axis endstop
- Example
- M577 E0 S1
M578: Fire inkjet bits
- Parameters
- Pnnn Inkjet head number
- Snnn Bit pattern
- Example
- M578 P3 S5
M579: Scale Cartesian axes
- Parameters
- Example
- M579 X1.0127 Y0.998
M580: Select Roland
- Parameters
- Example
- M580 R1 PVS4;!VZ2;!MC1;
- Parameters
- Example
M582: Check external trigger
- Parameters
- T Trigger number to poll
- Example
M583: Wait for pin
- Parameters
- Pnnn Pin number
- Example
M584: Set drive mapping
- Parameters
- Example
M585: Probe Tool
- Parameter; one of
- Xnnn
- Y-nnn
- Znnn
So the process should be:
- Example
- M590
- echo: Extruder 0x00
M600: Set line cross section
Example: M600 P0.061
M600: Filament change pause
Example: M600
Example: M605 S1
M665: Set delta configuration
- Parameters
- Lnnn Diagonal rod length
- Rnnn Delta radius
- Snnn Segments per second1
- Bnnn Safe printing radius2
- Examples
- Notes
1Only supported on Marlin.
- Parameters
- Annn X bed tilt in percent1
- Bnnn Y bed tilt in percent1
- Example
- M666 X-0.1 Y+0.2 Z0
M667: Select CoreXY mode
- Parameters
- Snnn CoreXY mode
- Xnnn X axis scale factor
- Ynnn Y axis scale factor
- Znnn Z axis scale factor
- Example
- M667 S1
Typical use would be:
M700: Level plate
Example: M700
M701: Load filament
1 only in bq-Marlin Firmware
Example: M701
M702: Unload filament
Example: M702
M703: Get Board Type
Example: M703
Example: M710
Example: M800
Example: M801
M851: Set Z-Probe Offset
M851 in Marlin 1.0.2
M851 in Marlin 1.1.0
M905: Set local date and time
- Parameters
- Example
- M905 P2016-10-26 S00:23:12
M906: Set motor currents
- Parameters
- Xnnn X drive motor current
- Ynnn Y drive motor current
- Znnn Z drive motor current
- Example
- Notes
M908 P<pin> S<current>
M909: Set microstepping
Example:
M909 X3 Y5 Z2 E3
M910: Set decay mode
Example:
M910 X3 Y5 Z2 E3
- Parameters
- Snnn Undervoltage threshold
- Tnnn Overvoltage threshold
Example:
M911 P0 S20 T27.5
- Parameters
Example:
M912 P0 S10.5
- Parameters
Example:
M928: Start SD logging
Example:
M928 filename.g
Stop SD logging with M29.
- Parameters
- Example
M998: Request resend of line
- Parameters
- Pnnn Line number
- Example
- M998 P34
- Parameters
- Pnnn Reset flags1
- Example
- M999
- Notes
Other commands
G: List all G-codes
Example: G
M: List all M-codes
Example: M
T: Select Tool
- Parameters
- Tool number
- Example
- T1
The sequence followed is:
- Use the new tool.
- (Old tool is released);
- (New tool is selected); and
- Notes
xx can be one of:
ok
rs
// action:command
ok
start
Exceptions:
- Resend: 8
- Writing to File: print.gco
- Done saving file.
- File selected
- M105 S2
- M105 S3
- M20 S2
- M36
- M408
Problem to solve
Alternatives to G-code
