G-коды
- 1 Введение
- 2 Синтаксис (Fields)
- 3 Комментарии
- 4 Специальные символы
- 5 Проверка
- 6 Буферизация
- 7 G-команды
- 7.1 G0 & G1: Перемещение
- 7.3 G4: Ожидание (Пауза)
- 7.7 G11: Подача
- 7.16 G30: Single Z-Probe
- 7.35 G131: Удалить смещения
- 8 M-commands
- 8.3 M2: Конец программы
- 8.7 M6: Tool change
- 8.15 M20: List SD card
- 8.17 M22: Release SD card
- 8.18 M23: Select SD file
- 8.20 M25: Pause SD print
- 8.21 M26: Set SD position
- 8.33 M37: Simulation mode
- 8.35 M40: Eject
- 8.36 M41: Loop
- 8.37 M42: Switch I/O pin
- 8.41 M70: Display message
- 8.44 M80: ATX Power On
- 8.45 M81: ATX Power Off
- 8.48 M84: Stop idle hold
- 8.61 M106: Fan On
- 8.62 M107: Fan Off
- 8.67 M111: Set Debug Level
- 8.68 M112: Emergency Stop
- 8.69 M113: Set Extruder PWM
- 8.72 M116: Wait
- 8.74 M117: Display Message
- 8.77 M120: Push
- 8.78 M121: Pop
- 8.81 M122: Diagnose
- 8.82 M123: Tachometer value
- 8.84 M126: Open Valve
- 8.85 M127: Close Valve
- 8.88 M130: Set PID P value
- 8.89 M131: Set PID I value
- 8.90 M132: Set PID D value
- 8.97 M142: Holding Pressure
- 8.99 M144: Bed Standby
- 8.106 M164: Store weights
- 8.116 M206: Offset axes
- 8.143 M240: Trigger camera
- 8.146 M245: Start cooler
- 8.147 M246: Stop cooler
- 8.150 M260: i2c Send Data
- 8.153 M300: Play beep sound
- 8.156 M303: Run PID tuning
- 8.187 M401: Lower z-probe
- 8.188 M402: Raise z-probe
- 8.205 M503: Print settings
- 8.207 M531: Set print name
- 8.210 M540: Set MAC address
- 8.211 M550: Set Name
- 8.212 M551: Set Password
- 8.213 M552: Set IP address
- 8.214 M553: Set Netmask
- 8.215 M554: Set Gateway
- 8.225 M564: Limit axes
- 8.240 M580: Select Roland
- 8.243 M583: Wait for pin
- 8.245 M585: Probe Tool
- 8.254 M700: Level plate
- 8.255 M701: Load filament
- 8.256 M702: Unload filament
- 8.257 M703: Get Board Type
- 8.267 M910: Set decay mode
- 9 Other commands
- 13 Alternatives to G-code
Введение
Поддержка | FiveD | Teacup | Sprinter | Marlin | Repetier | Smoothie | RepRapFirmware | Machinekit | MakerBot | grbl | Redeem | MK4duo |
Да | automatic | Нет | Частично | Экспериментально | deprecated | ??? | ??? | ??? | ??? | Да | Частично |
Обозначения:
- {{yes}}
- {{automatic}}
- {{no}}
- {{deprecated}}
Синтаксис (Fields)
Команда | Описание |
Gnnn | Стандартная команда, переход к заданной точке |
Mnnn | RepRap- ориентированные команды. Например включение вентилятора |
Tnnn | Выберите инструмент NNN. В RepRap, инструмент, как правило, ассоциируется с соплом или печатающей головкой, которая может работать с одиним или более экструдеров. |
Snnn | Команды, такие как время в секундах; температура; напряжение. |
Pnnn | Команды, такие как время в миллисекундах; для задания значений Kp для настройки ШИМ (PID) |
Xnnn | Координата X, используется обычно для перемещения по данной координате. Может быть целым или дробным числом. |
Ynnn | Координата Y, используется обычно для перемещения по данной координате. Может быть целым или дробным числом. |
Znnn | Координата Z, используется обычно для перемещения по данной координате. Может быть целым или дробным числом. |
U,V,W | Дополнительные координатные оси (в RepRap прошивках) |
Innn | Параметр смещения координаты Y при движении по дуге. Или для задания значений Ki для настройки ШИМ (PID) |
Jnnn | Параметр смещения координаты Y при движении по дуге |
Dnnn | Параметр используется для задания диаметра. Или для задания значений Ki для настройки ШИМ (PID) |
Hnnn | Параметр используемый для выбора номера печатающей головки для ШИМ (PID) регулирования |
Fnnn | Скорость подачи в мм в минуту. (Скорость движения печатающей головки) |
Rnnn | Параметр используемый для задания температуры |
Qnnn | Не используется в настоящее время |
Ennn | Длина экструдирования (выдавливания пластика). Используется и задается так же как для координат X, Y и Z, но применима к длине нити. |
Nnnn | Номер строки. Используется для запроса повторной передачи в случае возникновения ошибок. |
*nnn | Контрольная сумма. Используется для проверки на наличие ошибок. |
Комментарии
Специальные символы
N: Номер линии
Да | Да | Да | Да | Да | ??? | Да | Да | ??? | ? | Да | Да |
Пример: N123
*: Контрольная сумма
Да | Да | Да | Да | Да | ??? | Да | ??? | ??? | ? | Нет | Да |
Пример: *71
Проверка
Буферизация
Да | Да | ??? | Да | ??? | ??? | Да | ??? | ??? | Да | Да | Да |
G-команды
Да | Да | Да | Да | Да | Да | Да | Да | Да | Да | Да | Да |
- G1 : Линейное перемещение
- Использование
- Parameters
- Пример
- Пояснения
Нет | Нет | Да | Да1 | Да | Да | Нет | Да | ??? | Да | Экспериментально | Да |
- Использование
- Параметры
- Пример
- Примечание
- Parameters
- Пример
- G4 P200
Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет |
- Параметры
- Пример SCARA робота
- Пример DELTA робота
Нет | Нет | Нет | Нет | Нет | Нет | Да | Да | ??? | ??? | Нет | Нет |
- Использование
- Параметры
- Xnnn смещение по оси X
- Ynnn смещение по оси Y
- Znnn смещение по оси Z 2
- Пример
Смотрите так же M585.
- Примечания
Нет | Нет | Нет | Да | Да: 0.92 | Да | dc42,ch | Нет | ??? | ??? | Нет | Да |
- Параметры
- Пример
- G10
G11: Подача
- Параметры
- G11
??? | ??? | ??? | Нет | ??? | ??? | Нет | Да | ??? | Да | Нет | Нет |
- G17 : XY (по умолчанию)
- G18 : ZX
- G19 : YZ
Да | Да | Да | Да | Да | Да | Да | Да | ??? | Да | Нет | Да |
- Пример
- G20
Да | Да | Да | Да | Да | Да | Да | Да | ??? | Да | Да | Да |
- Пример
- G21
Нет | Нет | Нет | Нет | Нет | Нет | Нет | Да | ??? | ??? | Нет | Нет |
- Usage
- G22 ; Откат
- G23 ; Противооткат/Подача
Да | Да | Да | Да | Да | Да | Да | Да | Да | Да | Да | Да1 |
- Параметры
- Пример
'X' , 'Y' и 'Z' параметры действуют только в качестве флагов. Любые вводимые координаты игнорируются. Например, G28 Z10
выполнится так же как и G28 Z
. Delta принтеры не имеют домашнего положения по каждой из осей, отдельный их запуск может привести к краху механики. На данных принтерах в исходное положение должны двигаться все три оси одновременно.
Marlin прошивка (версия 1.1.0 и выше) имеет функцию под названием Z_SAFE_HOMING
для принтеров, которые используют Z щуп (механизм калибровки) для возврата в исходное положение вместо концевого выключателя. С помощью этой опции, оси XY возвращаются в исходное положение первыми, а затем ось Z безопасно приближается к соплу.
RepRapFirmware использует макро-файлы для возврата в исходное положение всех осей или отдельных осей. Для всех осей используется файл homeall.g
. Для отдельных осей ''homex.g
, homey.g
, или homez.g
. На Delta принтерах, команда G28 всегда будет возвращать в исходное положение все три оси, вне зависимости от параметров X Y Z и использует файл homedelta.g
- Примечания
Нет | Нет | Нет | Да | Да: 0.91.7 | Нет, see G32 | Да, 1.17 and later | Да | ??? | ??? | Да | Да |
- Использование
- G29
- G29 Snnn
- Параметры
- Пример
Marlin firmware (version 1.0.2 and up) provides a MESH_BED_LEVELING
feature that can be used to perform bed leveling on machines lacking a probe. This form of bed leveling compensates for uneven Z height across the surface of the bed using a mesh and bilinear interpolation.
- Manual Bed Leveling Usage
- Options for the S parameter
- S0 Produces a mesh report
G29 in Repetier firmware
G29 in RepRapFirmware
RepRapFirmware:
- S2 Clear bed height map
To define the grid, see M557.
- Пример
G29.1 X30 Y20 Z0.5
Example: G29.2 Z0.0
G30: Single Z-Probe
Нет | use G28 & G92 | Нет | Да | Да | Да | Да | Да | ??? | ??? | Да | Да1 |
- Usage
- Parameters
- Pnnn Probe point number
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- Hnnn Height correction
- Snnn Set parameter
- Examples
- G30
- Examples (RepRapFirmware)
- Usage
- Parameters
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- E Adjust Endstop
- I Adjust Tower
- D Adjust Diagonal Rod
- T Adjust Tower Radius
Нет | Нет | Нет | Нет | Да: 0.91.7 | Да | Да | Нет | ??? | ??? | Нет | Нет |
- Usage
- Parameters
- Pnnn Trigger value
- Xnnn Probe X offset1
- Ynnn Probe Y offset1
- Znnn Trigger Z height
- Examples
- G31 P500 Z2.6
- G31 X16.0 Y1.5
- Notes
Нет | Нет | Нет | Да | ??? | Нет | Нет | Нет | ??? | ??? | Да | Да |
Нет | Нет | Нет | Нет: See G29 | Да: 0.92.8 | Да | Да | Нет | ??? | ??? | Нет | Нет |
- Usage
- G32
- G32 Snnn
- Parameters
- Examples
- G32
- G32 S2
- Notes
Нет | Нет | Нет | Нет | Да: v0.92.8 | Нет | Нет | Нет | ??? | ??? | Да | Нет |
- Использование
- G33
- G33 Lnnn
- G33 Rnnn
- G33 Xnnn Ynnn Znnn
- Параметры
- L0 Вывод карты неровностей
- R0 Сброс карты неровности
- Пример
- G33
- G33 R0
??? | ??? | ??? | Да: 1.1.0 | ??? | Да | Нет | ??? | ??? | Да | Нет | Нет |
??? | ??? | ??? | ??? | ??? | ??? | Нет | ??? | ??? | Да | Нет | Нет |
??? | ??? | ??? | ??? | ??? | ??? | Нет | Да | ??? | Да | Нет | Нет |
??? | ??? | ??? | ??? | ??? | Да | Нет | Да | ??? | Да | Нет | Нет |
??? | ??? | ??? | ??? | ??? | ??? | ??? | ??? | ??? | ??? | ??? | Да |
- Применение
- G60 Snn
- Парамтеры
- Использование
- Параметры
- Xnnn X координата
- Ynnn Y координата
- Znnn Z координата
- Ennn E координата
Пример: G90
Пример: G91
- Параметры
- Xnnn новая координата X
- Ynnn новая координата Y
- Znnn новая координата Z
- Пример
- G92 X10 E90
??? | ??? | ??? | ??? | ??? | Да | Нет | ??? | ??? | Да | Нет | Нет |
Нет | Нет | Нет | Нет | Да: 0.92 | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
- Parameters
- Rnnn Radius to add
- Examples
Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | Да | ??? | Нет | Нет |
Нет | Нет | Нет | Нет | Да: 0.91 | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
Нет | Да | Нет | Нет | Нет | Нет | Нет | Нет | Да | ??? | Нет | Нет |
- Параметры
- Пример
- G161 X Y Z F1800
- Параметры
- Пример
- G162 X Y Z F1800
M-commands
Да | Да | Нет | Да | Нет | Нет | Да | Да | ??? | Да | Нет | Да |
- Parameters
- Example
- M0
- Notes
2Only available on Marlin.
Нет | ??? | Нет | Да | Нет | Нет | Да | Нет | ??? | Да | Нет | Да |
- Example
- M1
M2: Конец программы
Нет | Да | Нет | Нет | Нет | ??? | Нет | Нет | Да | Да | Нет | Нет |
Пример: M2
Нет | Да | Нет | Нет | Да | Да | Да | Нет | ??? | Да | Нет | Нет |
- Параметры
- Snnn Скорость шпинделя
- Пример
- M3 S4000
Прошивка Teacup поворачивает экструдер (так же, как M101).
Нет | Нет | Нет | Нет | Да | Нет | Нет | Нет | ??? | Да | Нет | Нет |
Пример: M4 S4000
Нет | Да | Нет | Нет | Да | Да | Нет | Нет | ??? | Да | Нет | Нет |
Example: M5
The spindle is turned off.
M6: Tool change
Нет | Да | Нет | Нет | Нет | ??? | Нет | Нет | ??? | ??? | Нет | Нет |
Example: M6
Нет | use M106 | Нет | Нет | Нет | Нет | Нет | Нет | ??? | Да | Нет | Нет |
Example: M7
Example: M8
Example: M9
Нет | use M106 | Нет | Нет | Нет | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
Example: M10
Example: M11
Нет | (automatic) | Нет | Да | Нет | Да | Нет | Нет | ??? | ??? | Да | Да |
Example: M17
Нет | use M2 | Нет | call M84 | Нет | Да | Да | Нет | Да | ??? | Да | call M84 |
- Parameters
- X X axis
- Y Y axis
- Z Z axis
- E Extruder drive(s)2
- Examples
- M18
- M18 X E0
- Notes
M20: List SD card
Нет | Да | Да | Да | Да | Да | Да | Нет | ??? | ??? | Нет | Да |
- Parameters
- Snnn Output style1
- Pnnn Directory to list2
- Examples
- M20
- M20 S2 P/gcodes/subdir
- Notes
M20 S2 P/gcodes {"dir":"\/gcodes","files":["4-piece-1-2-3-4.gcode","Hinged_Box.gcode","Hollow_Dodecahedron_190.gcode","*Calibration pieces"]}
- Parameters
- Examples
- M21
- M21 P1
Нет | Да | Да | Да | Да | Нет | Да | Нет | ??? | ??? | Нет | Да |
- Parameters
- Examples
- M22
- M22 P1
M23: Select SD file
- Example
- M23 filename.gco
Нет | Да | Да | Да | Да | Да | Да | Нет | ??? | ??? | Да | Да |
- Example
- M24
M25: Pause SD print
- Example
- M25
Нет | Нет | Да | Да | Да | aborts | Да | Нет | ??? | ??? | Нет | Да |
- Parameters
- Snnn File position in bytes
- Example
- M26
Нет | Нет | Да | Да | Да | Да | Да | Нет | ??? | ??? | Нет | Да |
- Example
- M27
Report SD print status.
SD printing byte 2134/235422
Not SD printing.
- Example
- M28 filename.gco
Нет | Нет | Да | Да | Да | Нет | Да | Нет | ??? | ??? | Нет | Да |
- Example
- M29 filename.gco
Нет | Нет | Да | Да | Да | Да | Да | Нет | ??? | Да | Нет | Да |
Example: M30 filename.gco
filename.gco is deleted.
M30 in grbl
Нет | Нет | Нет | Да | Нет | Нет | Нет | Нет | ??? | ??? | Нет | Да |
- Example
- M31
The response looks like:
echo:54 min, 38 sec
Нет | Нет | Нет | Да | Нет | Да | Да | Нет | ??? | ??? | Нет | Нет |
- Example
- M32 filename.gco
Нет | Нет | Нет | Да | Нет | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
Нет | Нет | Нет | Нет | Нет | Нет | Да | Нет | Нет | ??? | Нет | Нет |
- Example
- M36 filename.gco
Нет | Нет | Нет | Нет | Нет | Нет | Да | Нет | ??? | ??? | Нет | Нет |
M37 gcodes/myfile.g
Cannot find file
M37 www/reprap.htm
M40: Eject
Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
See also M240 and M241 below.
M41: Loop
Example: M41
M42: Switch I/O pin
Нет | Нет | Да | Да | Да | Нет | Да | Нет | Нет | ??? | Нет | Да |
- Parameters
- Pnnn Pin number
- Snnn Pin value
- Example
- M42 P7 S255
P | Name | Expansion Port Pin |
16 | TXD1 | 11 |
17 | RXD1 | 12 |
18 | TXD0 | 13 |
19 | RXD0 | 14 |
20 | TWD1 | 35 |
21 | TWCK1 | 36 |
23 | PA14 | 10 |
36 | PC4 | 18 |
52 | AD14 | 41 |
67 | PB16 | 32 |
60 | PA10/RXD0 | 14 |
61 | PA11/TXD0 | 13 |
62 | PA12/RXD1 | 12 |
63 | PA13/TXD1 | 11 |
64 | PA14/RTS1 | 10 |
65 | PB12/TWD1 | 35 |
66 | PB13/TWCK1 | 36 |
67 | PB16/DAC1* | 32 |
68 | PB21/AD14 | 41 |
69 | PC4 | 18 |
P | Signal Name | Expansion Connector Label |
60 | CS5 | CS5 |
61 | CS6 | E3_STOP |
62 | CS7 | E4_STOP |
63 | CS8 | E5_STOP |
Pre-1.16 example:
See also M583.
Example: M43
M43: Pin report and debug
- Usage
- M43 En Pnnn Wn In
- Parameters
- Parameters
- Pnnn number of points
- Xnnn position on the X axis
- Ynnn position on the Y axis
- Vnnn verbosity
- E engage
- Lnnn legs of travel
M70: Display message
Нет | Нет | Нет | see M117 | Нет | ??? | see M117 | Нет | Да | ??? | see M117 | see M117 |
Example:
M70 P200 Message
M72: Play a tone or song
Нет | Нет | Нет | see M300 | Нет | Нет | see M300 | Нет | Да | ??? | Нет | see M300 |
Example: M72 P2
M73: Set build percentage
Example: M73 P50
M80: ATX Power On
Нет | automatic | Да | Да | Да | Нет | Да | Нет | ??? | ??? | Нет | Да |
- Example
- M80
M81: ATX Power Off
Нет | automatic | Да | Да | Да | Нет | Да | Нет | ??? | ??? | Да | Да |
- Example
- M81
- Example
- M82
- Example
- M83
M84: Stop idle hold
- Parameters
- Innn Reset flags1
- Example
- M84
- Notes
Нет | Нет | Да | Да | Да | Нет | Нет | Нет | ??? | ??? | Нет | Да |
Example: M85 S30
M92: Set axis_steps_per_unit
Нет | Нет | Да | Да | Да | Да | Да | Нет | ??? | ??? | Да | Да |
- Parameters
- Examples
- M92 X87.489 Y87.489 Z87.489
- M92 E420:420
M93: Send axis_steps_per_unit
Нет | Нет | Да | Нет | ??? | Нет | Use M92 | Нет | ??? | ??? | Нет | Нет |
M98: Call Macro/Subprogram
- Parameters
- Pnnn Macro filename
- Example
- M98 Pmymacro.g
- Example
- M99
Returns from an M98 call.
M98: Get axis_hysteresis_mm
Example: M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Proposed for Marlin
Нет | Да | Нет | Нет | Нет | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
Да | Да | Да | Да | Да | Да | Да | Да | Да | ??? | Да | Да |
- Parameters
- Snnn Target temperature
- Example
- M104 S190
M104 in Teacup Firmware
Example: M104 P1 S100
Да | Да | Да | Да | Да | Да | Да | Нет | Да | ??? | Да | Да |
- Parameters
- Snnn Response type1
- Examples
- M105
- M105 S2
ok T:201 B:117
- Notes
M106: Fan On
Поддержка | FiveD | Teacup | Sprinter | Marlin | Repetier | Smoothie | RepRapFirmware | Machinekit | MakerBot | grbl | Redeem | MK4duo |
Да | Да | Да | Да | Да | Да | Да | Да | ??? | ??? | Да | Да |
- Parameters
- Extra Parameters
- Examples
- M106 S127
- M106 P1 I1 S871
- M106 P1 T45 H1:21
- M106 P2 B0.1 L0.051
- Notes
M106 in RepRapFirmware
M106 in Teacup Firmware
Example: M106 P2 S255
M107: Fan Off
Да | Нет | Да | Да | Да | Да | Да | Да | ??? | ??? | Да | Да |
M108: Cancel Heating (Marlin)
Да | not needed | Да | Да | Да | Да | Да | Да | Да | ??? | Да | Да |
- Parameters
- Example
- M109 S215
M109 in Teacup
Example: M109 S185
M109 in Sprinter (4pi port)
M109 in MakerBot
Example: M109 S70 T0
M110: Set Current Line Number
Да | not needed | Нет | Да | Да | Да | Да | Нет | ??? | ??? | Да | Да |
- Parameters
- Nnnn Line number
- Example
- M110 N123
M111: Set Debug Level
Да | Debug | Нет | Да | Да | Нет | Да | Нет | ??? | ??? | Да | Да |
- Parameters
- Pnnn Debug module1
- Snnn Debug on/off
- Examples
- M111 S6
- M111 P1 S1
- Notes
M111 in RepRapFirmware
M111 in Repetier
M112: Emergency Stop
Да | Да | Нет | Да | Да | Да | Да | Нет | ??? | ??? | Да | Да |
- Example
- M112
M113: Set Extruder PWM
Да | Нет | Нет | Нет | Нет | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
Example: M113
M113 S0.7
M114: Get Current Position
- Example
- M114
Да | Да | Да | Да | Да | Нет | Да | Нет | Нет | ??? | Да | Да |
- Parameters
- Pnnn Electronics type1
- Examples
- M115
- M115 P2
sample data from firmware:
- Notes
M116: Wait
Да | Да | Нет | Нет | Да | Нет | Да | Нет | Да | ??? | Да | Нет |
- Parameters
- Pnnn Tool number
- Hnnn Heater number
- Cnnn Chamber number
- Examples
- M116
- M116 P1
- Notes
M117: Get Zero Position
Да | Нет | Нет | Нет | Нет | Нет | Нет | Нет | see M70 | ??? | Нет | Нет |
Example: M117
M117: Display Message
Нет | Нет | Нет | Да | Да | Да | Да | Нет | Нет | ??? | Да | Да |
- Example
- M117 Hello World
M118: Negotiate Features
Example: M118 P42
M119: Get Endstop Status
- Example
- M119
- Example
- M119 X1 1
M120: Push
Нет | Нет | Нет | Нет | Нет | Да | Да | Нет | ??? | ??? | Нет | Нет |
- Example
- M120
- Current feedrate, and
- Current feedrate
- Extruder positions
M121: Pop
- Example
- M121
M122: Diagnose
- Example
- M122
M123: Tachometer value
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
Да | Нет | Нет | Да | Нет | Нет | Нет | Нет | Да | ??? | Нет | Да |
Example: M126 P500
M126 in MakerBot
Example: M126 T0
M127: Close Valve
Example: M127 P400
M127 in MakerBot
Example: M127 T0
M128: Extruder Pressure PWM
Example: M128 S255
M129: Extruder pressure off
Example: M129 P100
M130: Set PID P value
Нет | Да | Нет | see M301 | Нет | see M301 | Нет | Нет | ??? | ??? | see M301 | see M301 |
- Parameters
- Pnnn heater number
- Snnn proportional (Kp)
- Example
M131: Set PID I value
- Parameters
- Snnn integral (Ki)
- Example
M132: Set PID D value
Нет | Да | Нет | see M301 | Нет | See M301 | see M301 | Нет | Да | ??? | see M301 | see M301 |
- Parameters
- Snnn derivative (Kd)
- Example
M132 in MakerBot
Example: M132 X Y Z A B
M133: Set PID I limit value
Нет | Да | Нет | see M301 | Нет | Нет | Нет | Нет | Да | ??? | see M301 | see M301 |
- Parameters
- Snnn integral limit (Ki)
- Example
M133 in MakerBot
Example: M133 T0 P500
Нет | Да | Нет | Нет | Нет | Нет: See M504 | see M500 | Нет | Да | ??? | Нет | Нет |
Example: M134
M134 in MakerBot
Example: M134 T0 P500
M135: Set PID sample interval
Нет | Нет | Нет | Нет | Нет | Нет | Да | Нет | Да | ??? | Нет | Нет |
- Parameters
- Example
- M135 S300
M135 in MakerBot
Example: M135 T0
Нет | Debug | Нет | Нет | Нет | Нет | see M301 | Нет | ??? | ??? | Нет | Нет |
- Parameters
- Hnnn Heater number1
- Example
- M140 S55
M140 S-273.15
Нет | uses M104 | Нет | Нет | Нет | Нет | Да | Да | ??? | ??? | Нет | Нет |
- Parameters
- Examples
- M141 S30
- M141 H0
- Notes
M142: Holding Pressure
Example: M142 S1
Example: M143 S275
M144: Bed Standby
- Example
- M144
M146: Set Chamber Humidity
- Parameters
- Example
- M146 R60
M149: Set temperature units
- Parameters
- Example
- M149 K
M150: Set display color
- Parameters
- Rnnn red
- Unnn green
- Bnnn blue
- Example
- M150 R255 U128 B192
Нет | Нет | Нет | Да: 1.1.0 | Да | Нет | Нет | Нет | ??? | ??? | Нет | Да |
- Parameters
- Example
- M155 S1
Cap:AUTOREPORT_TEMP:1
Example: M160 S4
Нет | Нет | Нет | Да: RC7 | Да: 0.92 | Нет | Use M567 | Нет | ??? | ??? | Нет | Нет |
- Parameters
- Snnn extruder number
- Pnnn weight
M164: Store weights
Нет | Нет | Нет | Да: RC7 | Да: 0.92 | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
- Parameters
Нет | Нет | Нет | Да: RC7 | Нет: | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
- Parameters ABCDHI
Нет | Нет: See M116 | Да | Да | Да | Да | Да | Да | ??? | ??? | Да | Да |
- Parameters
- Example
- M190 S60
Нет | Нет | Нет | Нет | Нет | Нет | see M301 C1 | Да | ??? | ??? | Нет | Нет |
Example: M191 P60
M200: Set filament diameter
Нет | Нет | Нет | Да | Да | Да | see M404 | Да | ??? | ??? | Нет | Да |
Нет | Нет | Да | Да | Да | Нет | Да | Нет | ??? | ??? | Да | Да |
- Parameters
- Example
- M201 X1000 Y1000 Z100 E2000
Нет | Нет | ??? | Да | Да | Нет | Нет | Нет | ??? | ??? | ??? | Да |
M203: Set maximum feedrate
Нет | Нет | ??? | Да | Да | Да | Да | Нет | ??? | ??? | ??? | Да |
- Parameters
- Example
M203 Repetier
Set temperture monitor to Sx.
Нет | Нет | Да | Да | Да | Да | Нет | Нет | ??? | ??? | ??? | Да |
P = Printing moves
M204 Repetier
M204 X[Kp] Y[Ki] Z[Kd] -
M205: Advanced settings
Нет | Нет | Да | Да | Да | Да | see M566 | Нет | ??? | ??? | ??? | Да |
Sprinter and Marlin:
Sprinter / Marlin Example:
Smoothie example:
M205 Repetier
Output EEPROM settings.
M206: Offset axes
Нет | Нет | Да | Да | Нет | Да | Да | Нет | ??? | ??? | Да | Да |
- Parameters
- Xnnn X axis offset
- Ynnn Y axis offset
- Znnn Z axis offset
- Example
- M206 X10.0 Y10.0 Z-0.4
Нет | Нет | Нет | Нет | Да | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
Example: M206 T3 P39 X19.9
Set Jerk to 19.9
Нет | Нет | Нет | Нет | ??? | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
Example: M207
M207: Set retract length
Нет | Нет | Нет | Да | Нет | Да | Да | Нет | ??? | ??? | Нет | Да |
- Parameters
- Znnn additional zlift/hop
- Example
- M207 S4.0 F2400 Z0.075
M208: Set axis max travel
- Parameters
- Xnnn X axis limit
- Ynnn Y axis limit
- Znnn Z axis limit
- Example
- M208 X250 Y210 Z180
- Notes
M208: Set unretract length
Нет | Нет | Нет | Да | Нет | Да | See M207 | Нет | ??? | ??? | Нет | Да |
- Parameters
- Fnnn feedrate, in mm/sec
Нет | Нет | Нет | Да | Да | Нет | Нет | Нет | Нет | ??? | Нет | Да |
Example: M209 S1
M210: Set homing feedrates
Example: M210 X1000 Y1500
Нет | Нет | Нет | Нет | Нет | Нет | Use M564 | Нет | ??? | ??? | Нет | Нет |
Example: M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example: M211 X0 S1
Enables X min endstop
Example: M211
Нет | Нет | Нет | Да* | Нет | Нет | Use G31 | Нет | ??? | ??? | Нет | Да |
Example: M212 Z-0.2
M218: Set Hotend Offset
Нет | Нет | Нет | Да | Нет | Нет | Use G10 | Нет | ??? | ??? | Нет | Да |
Example: M218 T1 X50 Y0.5
- Parameters
- Example
- M220 S80
- Parameters
- Example
- M221 S70
- M221 S95 D1
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
Нет | Нет | Нет | Нет | Нет | Нет | Да | Да | ??? | ??? | Нет | Нет |
- Example
- M226
M226: Wait for pin state
Нет | Нет | Нет | Да | Да | Нет | see M577 | Нет | ??? | ??? | Нет | Да |
- Parameters
- Pnnn pin number
- Snnn pin state
- Example
- M226 P2 S1
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
M231: Set OPS parameter
M240: Trigger camera
Example: M240
Нет | Debug: Echo off | Нет | Нет | Нет | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
Example: M240
Нет | Debug: Echo on | Нет | Нет | Нет | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
M250: Set LCD contrast
Нет | Нет | Нет | Да | Нет | Нет | Нет | Нет | Нет | ??? | Нет | Да |
Example: M250 C20
M260: i2c Send Data
Нет | Нет | Нет | Да: 1.1.0 | Нет | Нет | Нет | Нет | Нет | ??? | Нет | Да |
- Examples
M261: i2c Request Data
- Example
Both M260 and M261 are commands demonstrating use of the i2c bus (TWIBus class) in Marlin Firmware. Developers and vendors can make Marlin an i2c master device by enabling EXPERIMENTAL_I2CBUS
, and Marlin can act as a slave device by setting I2C_SLAVE_ADDRESS
from 8-127. This class can be used to divide up processing responsibilities between multiple instances of Marlin running on multiple boards. For example, one board might control a Z axis with 4 independent steppers to create a self-leveling system, or a second board could drive the graphical display while the first board handles printing.
M280: Set servo position
Нет | Нет | Нет | Да | Use M340 | Нет | 1.16 and later | Да | ??? | ??? | Да | Да |
Set servo position absolute.
- Parameters
- Pnnn Servo index
- Snnn Angle or microseconds
- Example
- M280 P1 S50
M300: Play beep sound
Нет | Нет | Нет | Да | Да | Нет | Да | Да | Да | ??? | Нет | Да |
- Parameters
- Snnn frequency in Hz
- Example
- M300 S300 P1000
M301: Set PID parameters
Нет | Нет: See M13[0-3]) | Да | Да | Да | Да | Да | Нет | ??? | ??? | Да | Да |
- Parameters
- Pnnn proportional (Kp)
- Innn integral (Ki)
- Dnnn derivative (Kd)
- Examples
- M301 H1 P1 I2 D3 ; Marlin
Marlin
I: Integral value
D: Derivative value
Smoothie
Other implementations
- M301 W125
Teacup
M302: Allow cold extrudes
Нет | Нет | Нет | Да | Да: 0.92 | Нет | Да1 | Нет | ??? | ??? | Нет | Да |
- Parameters
- Examples (RepRapFirmwre)
- M302 ; Report current state
- Examples (Others)
- Notes
M303: Run PID tuning
Нет | Нет | Да | Да | Да | Да | 1.15 and later | Нет | ??? | ??? | Да | Да |
Hot end usage:
M303 S<temperature> C<cycles>
M303 P1 S<temperature>
Bed usage (others):
Example:
M303 C8 S175
M303 E0 S190
- Notes
Нет | Нет | Нет | Да | ??? | see M301 | Да | Нет | ??? | ??? | Нет | Да |
- Parameters
- Examples
- M304 ; Report parameters
Нет | Нет | Нет | Нет | ??? | Да | Да | Нет | ??? | ??? | Нет | Нет |
- Parameters
- Pnnn Heater number
- Rnnn Series resistor value
- Lnnn ADC low offset
- Hnnn ADC high offset
- Example
- M305 P1 T100000 R1000 B4200
Нет | Нет | Нет | Нет | ??? | Да | Нет | Нет | ??? | ??? | Нет | Нет |
Example: M306 Z0
Implemented in Smoothieware
Нет | Нет | Нет | Нет | Нет | Нет | 1.15 and later | Нет | ??? | ??? | Нет | Нет |
- Parameters
- Dnnn Dead time in seconds
- Examples
- Usage
- M320
- M320 S1
- Parameters
- Examples
Parameter Snnn is optional.
(Repetier only)
- Usage
- M321
- M321 S1
- Parameters
- Examples
(Repetier only)
- Usage
- M322
- M322 S1
- Parameters
- Examples
(Repetier only)
- Usage
- M323
- M323 Snnn
- M323 Snnn Pnnn
- Parameters
- Examples
M340: Control the servos
M350: Set microstepping mode
Нет | Нет | Нет | Да | Да | Нет | Да | Нет | ??? | ??? | Да | Да |
Sets microstepping mode.
- Usage
- Parameters
- Modes (nn)
- 1 = full step
- 2 = half step
- 4 = quarter step
- 8 = 1/8 step
- 16 = 1/16 step
- 64 = 1/64 step
- 128 = 1/128 step
- 256 = 1/256 step
- Examples
Нет | Нет | Нет | Да | Нет | Нет | Нет | Нет | ??? | ??? | Нет | Да |
Example: M351
M355: Turn case lights on/off
Нет | use M106 | Нет | Нет | Да: 0.92.2 | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
- Examples
- M355 S1 ; Enable lights
- M355 S0 ; Disable lights
- M355 ; Report status
Нет | Нет | Нет | Нет | Да: 0.92.2 | Нет | Нет | Нет | ??? | ??? | Нет | Нет |
- Target
- Example
- M360
- Response
Нет | Нет | Нет | Частично | Нет | Да | Нет | Нет | ??? | ??? | ??? | Частично |
Нет | Нет | Нет | Экспериментально | Нет | Да | Нет | Нет | ??? | ??? | Нет | Экспериментально |
M365: SCARA scaling factor
M366: SCARA convert trim
Нет | Нет | Нет | Нет | Нет | Да | Нет | Нет | ??? | ??? | Нет | Нет |
- Usage
- M370
Нет | Нет | Нет | Нет | Нет | Да | Нет | Нет | ??? | ??? | ??? | Нет |
M374: Save calibration grid
- Usage
- M374
- M374 <file extension> Z
- Usage
- M375
- M375 <file extension>
M380: Activate solenoid
Нет | Нет | Нет | Да | ??? | Нет | Нет | Нет | ??? | ??? | ??? | Да |
Example: M380
M381: Disable all solenoids
Example: M381
Нет | use G4 | Да | Да | Да | Да | Да | Да | ??? | ??? | ??? | Да |
- Example
- M400
Finishes all current moves and and thus clears the buffer. That's identical to G4 P0
M401: Lower z-probe
Example: M401
Lower z-probe if present.
M402: Raise z-probe
Example: M402
Raise z-probe if present.
Нет | Нет | Нет | Да | Нет | Нет | Да | Нет | ??? | ??? | ??? | Да |
- Parameters
- Nnnn Filament width (in mm)
- Examples
- M404 N1.75
- M404 N3.0 D1.0
- Notes
M405: Filament Sensor on
Нет | Нет | Нет | Да | Нет | Нет | Нет | Нет | ??? | ??? | ??? | Да |
Example: M405
M406: Filament Sensor off
Example: M406
- Example
- M407
Нет | Нет | Нет | Нет | Нет | Нет | Да | Нет | ??? | ??? | ??? | Нет |
- Parameters
- Snnn Response type
- Example
- M408 S0
{"status":"I","heaters":[25.0,29.0,28.3],"active":[-273.1,0.0,0.0],"standby":[-273.1,0.0,0.0],"hstat":[0,2,1],"pos":[-11.00,0.00,0.00],"extr":[0.0,0.0], "sfactor":100.00, "efactor":[100.00,100.00],"tool":1,"probe":"535","fanPercent":[75.0,0.0],"fanRPM":0,"homed":[0,0,0],"fraction_printed":0.572}
status: I=idle, P=printing from SD card, S=stopped (i.e. needs a reset), C=running config file, A=paused, D=pausing, R=resuming, B=busy (running a macro) heaters: current heater temperatures, numbered as per the machine (typically, heater 0 is the bed) active: active temperatures of the heaters standby: standby temperatures of the heaters hstat: status of the heaters, 0=off, 1=standby, 2=active, 3=fault pos: the X, Y and Z positions of the current tool (if a tool is selected), or the print head reference point if no tool is selected extr: the positions of the extruders sfactor: the current speed factor (see M220 command) efactor: the current extrusion factors (see M221 command) tool: the selected tool number. A negative number typically means no tool selected. probe: the Z-probe reading fanPercent: the speeds of the controllable fans, in percent of maximum fanRPM: the cooling fan RPM homed: the homed status of the X, Y and Z axes (or towers on a delta). 0=axis has not been homed so position is not reliable, 1=axis has been homed so position is reliable. fraction_printed: the fraction of the file currently being printed that has been read and at least partially processed. message: the message to be displayed on the screen (only present if there is a message to display) timesLeft: an array of the estimated remaining print times (in seconds) calculated by different methods. These are currently based on the proportion of the file read, the proportion of the total filament consumed, and the proportion of the total layers already printed. Only present if a print from SD card is in progress. seq: the sequence number of the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater than that. resp: the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater.
Поддержка | FiveD | Teacup | Sprinter | Marlin | Repetier | Smoothie | RepRapFirmware | Machinekit | MakerBot | grbl | Redeem | MK4duo |
Нет | Нет | Нет | Нет | Нет | Нет | Нет | Да | ??? | ??? | ??? | Нет |
Example: M420 R255 E255 B255
Example: M420 S1
M450: Report Printer Mode
Нет | Нет | Нет | Нет | Да | Нет | Нет | Нет | ??? | ??? | ??? | Нет |
Usage: M450
- PrinterMode:FFF
- PrinterMode:Laser
- PrinterMode:CNC
M451: Select FFF Printer Mode
- Usage
- M451
- Example
- M451
- Output
- PrinterMode:FFF
- Usage
- M452
- Example
- M452
- Output
- PrinterMode:Laser
M453: Select CNC Printer Mode
- Usage
- M453
- Example
- M453
- Output
- PrinterMode:CNC
- Usage
- M460 X<minTemp> Y<maxTemp>
- Example
- M460 X50 Y60
Нет | Нет | Да | Да | Да | ??? | Да | Нет | ??? | ??? | ??? | Да |
- Example
- M500
- Parameters
- Example
- M501
- Example
- M502
M503: Print settings
Нет | Нет | Да | Да | ??? | ??? | Да | Нет | ??? | ??? | ??? | Да |
- Example
- M503
M530: Enable printing mode
Нет | Нет | Нет | Нет | Да | ??? | Нет | Нет | ??? | ??? | ??? | Да |
- Example
M530 S1 L270
Cap:PROGRESS:1
M531: Set print name
- Example
M531 Demo Model
M532: Set print progress
- Example
- M532 X23.7 L56
- Parameters
- Example
- M540 S1
M540: Set MAC address
- Parameters
- Pnnn The MAC address
- Examples
- M540 PDE:AD:BE:EF:CA:FE
M550: Set Name
- Parameters
- Pnnn Machine name
- Example
- M550 PGodzilla
M551: Set Password
- Parameters
- Pnnn Password
- Example
- M551 Pmy-very-secret-word
M552: Set IP address
- Parameters
- Pnnn IP address
- Rnnn HTTP port (default 80)
- Example
- M552 P192.168.1.14
M553: Set Netmask
- Parameters
- Pnnn Net mask
- Example
- M553 P255.255.255.0
M554: Set Gateway
- Parameters
- Pnnn Gateway
- Example
- M554 P192.168.1.1
M555: Set compatibility
- Parameters
- Pnnn Emulation type
- Example
- M555 P1
P value | Firmware |
0 | Native (i.e. whatever the firmware actually is) |
1 | RepRap_Firmware |
2 | Marlin |
3 | Teacup |
4 | Sprinter |
5 | Repetier |
M556: Axis compensation
- Parameters
- Example
- M556 S100 X0.7 Y-0.2 Z0.6
Нет | Нет | Нет | Нет | Нет | Да | Да | Нет | ??? | ??? | ??? | Нет |
- Pnnn Probe point number
- Xnnn X coordinate
- Ynnn Y coordinate
- Example
- M557 P1 X30 Y40.5
- R Radius to probe
- S Probing interval
- Examples
- M557 X0:200 Y0:220 S20
- M557 R150 S15
M558: Set Z probe type
- Parameters
- Pnnn Z probe type
- Xnnn Use probe for X axis
- Ynnn Use probe for Y axis
- Znnn Use probe for Z axis
- Hnnn Dive height1
- Example
- M558 P0 X1 Y0 Z1
- Notes
- Example
- M559
M560: Upload web page file
- Example
- M560
<!-- **EoF** -->
M561: Set Identity Transform
- Example
- M561
M562: Reset temperature fault
- Parameters
- Example
- M562 P2
M563: Define or remove a tool
- Parameters
- Pnnn Tool number
- Dnnn Extruder drive(s)
- Hnnn Heater(s)
- Example
M563 S1
M563 P1 D-1 H-1
M564: Limit axes
- Parameters
- Example
- M564 S0
M565: Set Z probe offset
Нет | Нет | Нет | Нет | Нет | Да | see G31 | Нет | ??? | ??? | ??? | Нет |
Example: M565 X3 Y4.5 Z-2.37
- Parameters
- Example
- M566 X20 Y20 Z2 E10
M567: Set tool mix ratios
- Parameters
- Pnnn Tool number
- Ennn Mix ratios
- Example
- M567 P2 E0.1:0.2:0.1:0.6
G1 X20 E1.3
See also M568.
- Parameters
- Pnnn Tool number
- Example
- M568 P2 S0
G1 X20 E0.2:0.4:0.166:0.3
The off state is the default.
- Parameters
- Pnnn Motor driver number
- Example
- M569 P0 S1
- Notes
- Example
- M570 S120
- Hnnn Heater number
- Example
- M570 H1 P4 T15
M571: Set output on extrude
- Parameters
- Snnn Output value
- Example
- M571 S0.5
Нет | Нет | Нет | Нет | Нет | Нет | dc42, ch, dn | Нет | ??? | ??? | ??? | Нет |
- Parameters
- Dnnn Extruder number
- Example
- M572 D0 S0.1
M573: Report heater PWM
- Parameters
- Example
- M573 P1
- Parameters
- Xnnn Switch type for X axis
- Ynnn Switch type for Y axis
- Znnn Switch type for Z axis
- Snnn Logic level
- Example
- M574 X1 Y2 Z0 S1
- Parameters
- Pnnn Serial channel number
- Bnnn Baud rate
- Example
- M575 P1 B57600 S1
Нет | Нет | Нет | Нет | Нет | Нет | Да | Нет | Нет | ??? | ??? | Нет |
- Parameters
- Snnn Desired endstop level
- Xnnn Select X axis endstop
- Ynnn Select Y axis endstop
- Znnn Select Z axis endstop
- Example
- M577 E0 S1
M578: Fire inkjet bits
- Parameters
- Pnnn Inkjet head number
- Snnn Bit pattern
- Example
- M578 P3 S5
M579: Scale Cartesian axes
- Parameters
- Example
- M579 X1.0127 Y0.998
M580: Select Roland
- Parameters
- Example
- M580 R1 PVS4;!VZ2;!MC1;
Нет | Нет | Нет | Нет | Нет | Нет | dc42 | Нет | Нет | ??? | ??? | Нет |
- Parameters
- Example
M582: Check external trigger
- Parameters
- T Trigger number to poll
- Example
M583: Wait for pin
Нет | Нет | Нет | Нет | Нет | Нет | {soon} | Нет | Нет | ??? | ??? | Нет |
- Parameters
- Pnnn Pin number
- Example
M584: Set drive mapping
Нет | Нет | Нет | Нет | Нет | Нет | Version 1.14 and later | Нет | Нет | ??? | ??? | Нет |
- Parameters
- Example
M585: Probe Tool
Нет | Нет | Нет | Нет | Нет | Нет | Шаблон:Soon | Нет | Нет | ??? | ??? | Нет |
- Parameter; one of
- Xnnn
- Y-nnn
- Znnn
So the process should be:
Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет |
- Example
- M590
- echo: Extruder 0x00
M600: Set line cross section
Нет | Нет | Нет | Нет | ??? | ??? | Нет | Да | ??? | ??? | ??? | Нет |
Example: M600 P0.061
M600: Filament change pause
Нет | Нет | Нет | Да | ??? | ??? | Use macro files instead | Нет | ??? | ??? | ??? | Да |
Example: M600
Нет | Нет | Нет | Да | ??? | Нет | Use M563 | Нет | ??? | ??? | ??? | Да |
Example: M605 S1
M665: Set delta configuration
Нет | Нет | Нет | Да | Нет | Да | Да | Нет | ??? | ??? | ??? | Да |
- Parameters
- Lnnn Diagonal rod length
- Rnnn Delta radius
- Snnn Segments per second1
- Bnnn Safe printing radius2
- Examples
- Notes
1Only supported on Marlin.
Нет | Нет | Нет | Да | Да | Да | Да | Нет | ??? | ??? | ??? | Да |
- Parameters
- Annn X bed tilt in percent1
- Bnnn Y bed tilt in percent1
- Example
- M666 X-0.1 Y+0.2 Z0
M667: Select CoreXY mode
- Parameters
- Snnn CoreXY mode
- Xnnn X axis scale factor
- Ynnn Y axis scale factor
- Znnn Z axis scale factor
- Example
- M667 S1
Нет | Нет | Нет | Нет | Нет | Нет | dc42-cmm | Нет | ??? | ??? | ??? | Нет |
Typical use would be:
M700: Level plate
Нет | Нет | Нет | bq | Нет | Нет | Нет | Нет | Нет | Нет | Нет | bq |
Example: M700
M701: Load filament
1 only in bq-Marlin Firmware
Example: M701
M702: Unload filament
Example: M702
M703: Get Board Type
Example: M703
Example: M710
Example: M800
Example: M801
M851: Set Z-Probe Offset
??? | ??? | ??? | Да | ??? | ??? | Use G31 | ??? | ??? | ??? | ??? | Да |
M851 in Marlin 1.0.2
M851 in Marlin 1.1.0
M905: Set local date and time
Нет | Нет | Нет | Нет | Нет | Нет | coming soon | Нет | ??? | ??? | Нет | Нет |
- Parameters
- Example
- M905 P2016-10-26 S00:23:12
M906: Set motor currents
Нет | Нет | Нет | Нет | Нет | M907? | Да | Нет | ??? | ??? | Да | Нет |
- Parameters
- Xnnn X drive motor current
- Ynnn Y drive motor current
- Znnn Z drive motor current
- Example
- Notes
Нет | Нет | Нет | Да | Да | Да | Use M906 | Нет | ??? | ??? | Да | Да |
Нет | Нет | Нет | Да | Да: 0.92 | Нет | Нет | Нет | ??? | ??? | ??? | Да |
M908 P<pin> S<current>
M909: Set microstepping
Нет | Нет | Нет | Use M350 | Use M350 | Нет | Use M350 | Нет | ??? | ??? | Да | Use M350 |
Example:
M909 X3 Y5 Z2 E3
M910: Set decay mode
Нет | Нет | Нет | Нет | Нет | Нет | Нет | Нет | ??? | ??? | Да | Нет |
Example:
M910 X3 Y5 Z2 E3
Нет | Нет | Нет | Нет | Нет | Нет | Да | Нет | ??? | ??? | Нет | Нет |
- Parameters
- Snnn Undervoltage threshold
- Tnnn Overvoltage threshold
Example:
M911 P0 S20 T27.5
- Parameters
Example:
M912 P0 S10.5
- Parameters
Example:
M928: Start SD logging
Example:
M928 filename.g
Stop SD logging with M29.
Нет | Нет | Нет | Нет | Нет | Нет | Да | Нет | Нет | ??? | Нет | Нет |
- Parameters
- Example
M998: Request resend of line
Нет | Нет | Нет | Нет | Нет | Нет | Да | Нет | ??? | ??? | ??? | ??? |
- Parameters
- Pnnn Line number
- Example
- M998 P34
- Parameters
- Pnnn Reset flags1
- Example
- M999
- Notes
Other commands
G: List all G-codes
??? | ??? | ??? | Нет | ??? | ??? | Нет | ??? | ??? | ??? | Да | Нет |
Example: G
M: List all M-codes
Example: M
T: Select Tool
Да | Да | Нет | Да | Да | Да | Да | ??? | ??? | ??? | Да | Да |
- Parameters
- Tool number
- Example
- T1
The sequence followed is:
- Use the new tool.
- (Old tool is released);
- (New tool is selected); and
- Notes
xx can be one of:
ok
rs
// action:command
ok
start
Exceptions:
- Resend: 8
- Writing to File: print.gco
- Done saving file.
- File selected
- M105 S2
- M105 S3
- M20 S2
- M36
- M408
Problem to solve
Alternatives to G-code
