ЧПУ станок с CO2 лазером
Re: ЧПУ станок с CO2 лазером
Непрочитанное сообщение 3D-SPrinter » 08 ноя 2018, 03:06
AlexDadNNov писал(а): ↑
08 ноя 2018, 00:00
Я может что то не понимаю
Это я не понимаю, зачем копаюсь в старых версиях Марлина и изобретаю велосипед, когда в 1.1.2 уже всё есть. :oops: Спасибо за наводку! :idea: Буду разбираться.
Configuration_adv.h
* Spindle & Laser control
* Add the M3, M4, and M5 commands to turn the spindle/laser on and off, and
* to set spindle speed, spindle direction, and laser power.
* SuperPid is a router/spindle speed controller used in the CNC milling community.
* Marlin can be used to turn the spindle on and off. It can also be used to set
* the spindle speed from 5,000 to 30,000 RPM.
* You'll need to select a pin for the ON/OFF function and optionally choose a 0-5V
* hardware PWM pin for the speed control and a pin for the rotation direction.
* See http://marlinfw.org/docs/configuration/ ... indle.html for more config details.
//#define SPINDLE_LASER_ENABLE
#if ENABLED(SPINDLE_LASER_ENABLE)
#define SPINDLE_LASER_ENABLE_INVERT false // set to "true" if the on/off function is reversed
#define SPINDLE_LASER_PWM true // set to true if your controller supports setting the speed/power
#define SPINDLE_LASER_PWM_INVERT true // set to "true" if the speed/power goes up when you want it to go slower
#define SPINDLE_LASER_POWERUP_DELAY 5000 // delay in milliseconds to allow the spindle/laser to come up to speed/power
#define SPINDLE_LASER_POWERDOWN_DELAY 5000 // delay in milliseconds to allow the spindle to stop
#define SPINDLE_DIR_CHANGE true // set to true if your spindle controller supports changing spindle direction
#define SPINDLE_INVERT_DIR false
#define SPINDLE_STOP_ON_DIR_CHANGE true // set to true if Marlin should stop the spindle before changing rotation direction
* The M3 & M4 commands use the following equation to convert PWM duty cycle to speed/power
* SPEED/POWER = PWM duty cycle * SPEED_POWER_SLOPE + SPEED_POWER_INTERCEPT
* where PWM duty cycle varies from 0 to 255
* set the following for your controller (ALL MUST BE SET)
#define SPEED_POWER_SLOPE 118.4
#define SPEED_POWER_INTERCEPT 0
#define SPEED_POWER_MIN 5000
#define SPEED_POWER_MAX 30000 // SuperPID router controller 0 - 30,000 RPM
//#define SPEED_POWER_SLOPE 0.3922
//#define SPEED_POWER_INTERCEPT 0
//#define SPEED_POWER_MIN 10
//#define SPEED_POWER_MAX 100 // 0-100%
#endif
Непрочитанное сообщение 3D-SPrinter » 08 ноя 2018, 03:10
zloyevgen писал(а): ↑
08 ноя 2018, 00:11
Это в какой версии? В древней, которую Андрей использует для SPrinter, про лазер ничего нет. Если в новых есть, то здорово!
Это всё моё ретроградство виновато! Я конечно же смотрел новую версию, но только модуль Configuration.h. Там про лазер тоже ничего нет. Для принтера не нашёл ничего полезного и решил "не мешать работать" старой, проверенной версии. Тем более, что эта новая хрень с наскока ничем не компилировалась (в том числе и последней Ардуиной IDE). А документацию... - ну кто-ж её читает? :lol:
zloyevgen
Благодарил (а): 39 раз
Непрочитанное сообщение zloyevgen » 08 ноя 2018, 11:01
08 ноя 2018, 03:10
Ретроградство не всегда плохо ;)
Новая фича.jpg (65.7 КБ) 4931 просмотр
Непрочитанное сообщение Alex Post » 08 ноя 2018, 18:34
"Работает - не трожь" заповедь старого программиста. :P Но тут то новое дело осваиваем, нужно свежие решения изучать :)
Это как я, когда дондолу к Спринтеру собрался прикручивать, начитался статей Fixoida на тудэе, скачал свежий на то время Марлин и полез по инструкции его править... В одно место в другое - все уже поправлено... WTF? Читаю описание на гитхабе - оказывается, они с этой версии поддержку дондолы добавили :) И так бывает ;)
Непрочитанное сообщение 3D-SPrinter » 08 ноя 2018, 23:14
08 ноя 2018, 18:34
А какая конкретная версия Марлина и на каком IDE компилируется? Естественно, с поддержкой лазера интересует. Вроде, с версии 1.1.2 лазер прикрутили.
И что характерно, даже на импортных форумах не нашёл упоминаний о применении стандартного Марлина на лазерных станках. Может, плохо искал? :?
Roman
Непрочитанное сообщение Roman » 19 ноя 2018, 11:53
08 ноя 2018, 23:14
В принципе любая на любой. IDE - лишь компилятор для c++, адаптированного под ардуино, и от версии к версии просто фиксятся баги и улучшается стабильность. А марлин - прошивка в виде с++ для работы с немалым перечнем оборудования в любых комбинациях, который постоянно дополняется и обрастает фишками.
Да и не знаешь, какие баги убраны в новых версиях,
потому лучше использовать последнюю.
Насчёт упоминаний - часто вижу, как на форуме русскоязычном форуме cnc Club (не реклама) народ собирает из говна и палок на ардуино, в том числе на марлине. Но все закономерно переходят на ruida или awc.
Андрей, а рельсы использованы Mgn12 с Китая? Я до сих пор очкую на свой лазер их ставить. Малейший люфт приведёт к гулянию лазерной точки. Во мне бурлит великая битва жабы (20-30 тыр за хивин) и опасения, что скупой платит дважды.
3D-Sprinter 232
sanders
Непрочитанное сообщение sanders » 19 ноя 2018, 15:27
08 ноя 2018, 23:14
08 ноя 2018, 18:34
Тоже только что проверил на Arduino 1.8.7 последняя забранная версия Марлина 1.1.9 собирается без ошибок.
Я тоже сторонник использования последних версий. Себе под спринтер настроил последний марлин со всеми плюшками. Новые версии забираю сразу из СВН, так видно какие изменения внесли, и нормально ли они мерджаться с тем, что я сам у себя менял.
Непрочитанное сообщение Alex Post » 19 ноя 2018, 16:34
Насколько я в курсе, бывает в новые версии IDE включают какие то плюшки, которые некорректно работают со старым кодом, и поэтому код не компилится. А бывает и наоборот. ИМХО только из-за этого рекомендуют пользоваться конкретной версией IDE
Непрочитанное сообщение 3D-SPrinter » 19 ноя 2018, 17:17
Roman писал(а): ↑
19 ноя 2018, 11:53
Это в принципе, а фактически всё гораздо хуже - стыкуются прошивки и IDE, примерно совпадающие по времени выхода. А новое старым не компилится, и старое новым соответственно.
Roman писал(а): ↑
19 ноя 2018, 11:53
Рельсы конечно же китайские. Здесь на них нет никакой нагрузки, они воздух возят - китайские вполне справятся. Хивин я вообще не рассматриваю, как экономически-нецелесообразные в данном применении. Да и подавляющее большинство станков китайские на китайских рельсах. ;)
sanders писал(а): ↑
19 ноя 2018, 15:27
Понял. Спасибо за информацию.
zloyevgen
Непрочитанное сообщение zloyevgen » 21 ноя 2018, 16:32
Андрей, а рельсы на лазере 12-е? Термообработанные или сырые?
Непрочитанное сообщение 3D-SPrinter » 21 ноя 2018, 23:42
21 ноя 2018, 16:32
12-е. На Х 600 мм, на Y 800 мм.
21 ноя 2018, 16:32
Да кто их знает? На Y получше рельс пришёл, на Х похуже. Но для принтеров и лазерных станков в общем-то любые рельсы подходят, потому что нагрузки на них стремятся к нулю. Они же фактически воздух возят, а не шпиндель на фрезере. ;)
zloyevgen
Непрочитанное сообщение zloyevgen » 21 ноя 2018, 23:47
21 ноя 2018, 23:42
Да кто их знает?
9-е, которые мне пришли, со следами подгоревшего масла от термообработки. Царапаются труднее, чем чистые 12-е. Отверстия крепежные чистые были?
21 ноя 2018, 23:42
В целом - да, но твердые шарики в мягких рельсах натереть всё равно могут канав, хотя и не скоро.
Непрочитанное сообщение 3D-SPrinter » 22 ноя 2018, 00:14
21 ноя 2018, 23:47
Чистота отверстий не показатель. Встречались и с чистыми отверстиями хорошие рельсы, и с грязными г-но. Но при такой цене грех жаловаться. Если на тот же лазерный станок поставить фирменные рельсы, то он сразу в 2 раза подорожает, и многие его даже не начнут собирать по такой цене. А китайская ботва худо-бедно пару лет поработает и сто раз себя окупит. А потом можно её и поменять (так же за копейки).
zloyevgen
Непрочитанное сообщение zloyevgen » 22 ноя 2018, 00:16
22 ноя 2018, 00:14
Соглашусь. Цена-качество для наших целей у китайщины супер :idea:
Непрочитанное сообщение 3D-SPrinter » 22 ноя 2018, 00:27
22 ноя 2018, 00:16
Давно пытаюсь найти российские рельсы, но пока их массово не делают. А зря, товар-то очень ходовой. Российские подшипники гораздо лучше китайских по той же цене. И рельсы, наверно, тоже получились бы лучше китайских и не сильно дороже.
